Cisco APIC EM IWAN loopback question
carl_townshend
Hi All
I am currently in process of deploying APIC-EM using the IWAN app to setup my routers.
I have a question around the address pools,
Am I right in saying for the dmvpn tunnels you must manually configure the loopback on the device first should you wish to use that to build the tunnel?
Secondly, when you add a loopback pool in under the hub site, will this create a loopback on the device for the pfr? If so why does pfr need a loopback?
cheers
0 Replies 0
