Cisco IOS in Cisco 6513 Switch
tabrez_shaikh
Cisco 6513 Switch having s72033-ipservicesk9_wan-mz.122-18.SXE6a.bin can you please provide me with a recent latest IOS to be upgrade to the latest.
Tabrez
6 Replies 6
Richard Michael
Hi Tabrez,
It should be running MSFC3/Sup 720,
Find below the link that will point to the latest image,
http://www.cisco.com/cisco/software/release.html?mdfid=280829702&catid=268437899&flowid=20015&softwareid=280805680&release=12.2.33-SXJ1&relind=AVAILABLE&rellifecycle=ED&reltype=latest
s72033-ipservicesk9_wan-mz.122-33.SXJ1.bin
Release Date: 30/JUN/2011
Size: 136620.82 KB (139899716 bytes)
Minimum Memory: DRAM:512MB   Flash:512MB
if you dont wish to run SXJ train you can go ahead and select the SXI series,
Ricky Micky
* Please Rate if the content was useful
Somasundaram Jayaraman
Pls find the details below
IP SERVICES SSH - DEFAULT
Download link
http://www.cisco.com/cisco/software/release.html?mdfid=280829702&flowid=20144&softwareid=280805680&release=12.2.33-SXJ1&rellifecycle=ED&relind=AVAILABLE&reltype=latest
You can also check the feature supported by this IOS using cisco Feature navigator
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Cheers
Somu
Rate helpful posts
Dear Jayaraman
With the above mention IOS will my WS-X6066-SLB-S-K9 and my SPAN , Capture configuration done on one of the port in core switch cisco 6513 will work properly.
when i have this IOS s72033-ipservicesk9_wan-mz.12.2-33.SXH3.bin in my core 6513 switch then my WS-X6066 Module shows power down  and when i load   12.2-18.SXE6a.bin it is showing the same module as up and running.
so my question is if i load the new IOs recommended by you will my Module and my SPAN Capture Configuration will work properly on 12.2-33 SXJ1.bin
waiting for your reply
Tabrez
Tabrez
Your SPAN session should be fine.
As for the CSM-S module, support was removed for this card from 12.2(33)SXH which is why you see it as powered down with SXH3 on your supervisor.
Support was then added back in with 12.2(33)SXI2 so if you go with SXJ you should be fine.
Jon
Hello Tabrez,
I echo jon on this, When we removed the CSM support in the SXH train we had a lots of Customer's not moving to this mature branch because of lack of CSM support, As always customer feedback made us to put the CSM support back on SXI train . it is introduced in SXI2 and support there after. SXJ is definetly not going to affect the CSM.
Link FYR(For your Reference)
http://www.cisco.com/en/US/docs/ios/12_2sx/12_2sxi/12_2_33_sxi2_newfeatlist.html
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.html#wp4657571
Ricky Micky
*Pls rate useful posts
15.X IOS for the Sup720 releasing next week.
