Cisco Nexus 3064 switch and VDC support
fsebera
Level 4
Level 4
Anyone know if  the Cisco Nexus 3064 switches support more than a single Virtual Device context (VDC)?
While I can ssh into a remote 3064 switch and run the sh vdc command, I see it has one VDC.
SwitchA# sh vdc ?
  SwitchA          VDC number 1
  resource         Show resource configuration for VDC
Thank you
Frank
Thanks for confirming Inayath!
Reza
5 Replies 5
Reza Sharifi
I think multiple VDCs is only supported on the 7000 series.
Sure would be nice to know for sure!!!!!
I would go with Reza. Currently the Nexus 7K is the only one were you can create multiple VDC on it. No other models are supported that feature as of now.( Hence answer is N3K doesnt support more VDC).
Inayath
Reza
Thanks for the conformation!!
Frank
