Cisco Router 7600 continiously rebooting issue
rajafurqan2011
Hi,  i have cisco 7606 and issue is router rebooted in 4 to 5 time in a day.  details given below and crashfile also attached.
Router#show version
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 15.0(1)S1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 29-Sep-10 02:28 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRE, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 15.0(1)S1, RELEASE SOFTWARE (fc1)
Router uptime is 10 hours, 12 minutes
Uptime for this control processor is 10 hours, 11 minutes
System returned to ROM by s/w reset (SP by error - a Software forced crash, PC 0x8361EFC)
System image file is "disk0:c7600rsp72043-adventerprisek9-mz.150-1.S1.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7606 (M8500) processor (revision 1.0) with 1900544K/131072K bytes of memory.
Processor board ID TBA06180199
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.1, (0x80390021)
CORE: E500, Version: 2.2, (0x80210022)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Last reset from power-on
1 SIP-400 controller (10 GigabitEthernet).
1 Virtual Ethernet interface
12 Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
18 Replies 18
Nope. Only TAC will be able to provide more information.
Leo Laohoo
Upgrade the firmware of the router.  It could be CSCsg20930.
Cisco 7600 Router was working fine for 1 year, but after upgrading switch in network, again reboot issue.
upgradation Reverted back, but reboot issue same
NAS-7606-QML uptime is 36 minutes
Uptime for this control processor is 36 minutes
System returned to ROM by s/w reset (SP by error - a Software forced crash, PC 0x83D5B4C)
**Crashinfo are attached**
 **Errors** On Router Console before reboot
SLOT 3: *Jun 18 12:41:27.710: %FABRIC_INTF_ASIC-5-FABRICSYNC_REQ: Fabric ASIC 0: Fabric sync requested after 1 sync errors on serial channel 2
SLOT 3: *Jun 18 12:41:28.502: %FABRIC_INTF_ASIC-5-FABRICSYNC_DONE: Fabric ASIC 0 Channel 2: Fabric sync done.
*Jun 18 12:42:41.126: %SGPM-3-POLICY_RULE_SERVICE_CONFIG_ERROR: Service () is configured incorrectly, service_failed event will be thrown
SLOT 3: *Jun 18 12:42:42.206: %FABRIC_INTF_ASIC-4-FABRICCRCERRS: Fabric ASIC 0: 27 Fabric CRC error events in 100ms period
SLOT 3: *Jun 18 12:42:58.262: %FABRIC_INTF_ASIC-5-FABRICSYNC_REQ: Fabric ASIC 0: Fabric sync requested after 1 sync errors on serial channel 2
SLOT 3: *Jun 18 12:42:59.118: %FABRIC_INTF_ASIC-5-FABRICSYNC_DONE: Fabric ASIC 0 Channel 2: Fabric sync done.
*Jun 18 12:43:40.346: %SGPM-3-POLICY_RULE_SERVICE_CONFIG_ERROR: Service () is configured incorrectly, service_failed event will be thrown
SLOT 3: *Jun 18 12:43:42.214: %FABRIC_INTF_ASIC-4-FABRICCRCERRS: Fabric ASIC 0: 24 Fabric CRC error events in 100ms period
 : Unexpected exception to CPU: vector 1300, PC = 0x0       , LR = 0xBA3A8EC
 : Unexpected exception to CPU: vector 700, PC = 0x1A2D38E0, LR = 0xA054470
*** System received an Illegal Opcode exception ***
signal= 0x4, code= 0x700, context= 0x12e84330
PC = 0x1a2d38e0, Vector = 0x700, SP = 0x139d9a2c
Copyright (c) 2011 by cisco Systems, Inc.
C7600-RSP720/RP platform with 2097152 Kbytes of main memory
*Jun 18 12:43:56.102: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Jun 18 12:43:54.990: SP: SP detected RP/Draco rebooting, resetting SP
*Jun 18 12:43:56.102: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
*** System received a Software forced crash ***
signal= 0x17, code= 0x1500, context= 0xd75f9a8
PC = 0x83d5b4c, Vector = 0x1500, SP = 0x1332f140
C7600-RSP720/SP platform with 1048576 Kbytes of main memory
Autoboot executing command: "boot disk1:c7600rsp72043-adventerprisek9-mz.152-2.S2.bin"
Initializing ATA monitor library...
WTF!
If you're going to edit out all the "juicy" bits, go to TAC. I can't decipher anything!
