Cisco Router DHCP config help.
dan_track
I want to setup my router to be adhcp server that also allows for it to list where the next-server is for any clients that do pxe booting. Can anyone help me regarding preparing such a configuration?
Dan
bret
Level 3
Level 3
your dhcp server should look something like this
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp pool name
network 192.168.1.0 255.255.255.0
default route 192.168.1.1
dns server 1.1.1.1 2.2.2.2 3.3.3.3
domain name
as for the pxe stuff you will need to put a hlper address in for your pxe server and you may need to allow some sort of broadcast I think.
raviprakash_leo
I am not sure if Cisco directly supports PXE booting. But this is a sample config of how a Cisco IP phone and call manager was set up with a Cisco router.
ip dhcp pool "name"
network 10.10.1.0 255.255.255.0
bootfile [name of bootstrap file]
dns-server 1.2.3.4 1.2.3.5
default-router 10.10.1.1
option 66 ip 10.10.2.100 <--- IP address of server
Note the "option 66" command specifies that the machine asking for IP address also is looking for a TFTP server to get the boot file from.
In the IP phone environment, the phones send a dhcp request with option 66. To spedify a list of TFTP servers, use option 150.
Hope that helps. I am assuming that you know all the other options required to setup a DHCP pool.
