Cisco TDR Test Question
Working off a WS-C4510R+E
Ran TDR test on a port and here are the results:
Gi4/34 1Gbps
1-2 54 +/-1m Unknown Terminated
3-6 54 +/-1m Unknown Terminated
4-5 36 +/-1m Unknown Open
7-8 36 +/-1m Unknown Open
I believe terminated represents "Normal" now in newer switches but two pairs show as Open. Is that a problem?
 Theorically not as Ethernet pinout is :
1 - TX+
2 - TX-
3 - RX+
6 - RX-
But , honestly, I dont like it. If one pin is not ok, I prefer fix it.
1 - TX+
2 - TX-
3 - RX+
6 - RX-
I will most likely replace the cable. It connects to an AP that has inconsistent speed tests. Upload is always good but every speed test the download speeds change.
Leo Laohoo
TDR result in a 4k and 6k are "different".
Terminated means "Normal".
Open means the same as the rest.
The result above means only Pair A & B are Terminated/Normal and C & D are OPEN.
The difference between Pairs A & B is very "off" to Pairs C & D.  Is there a consolidation point in the roof?
