Clarification - Fixed Configuration
dj214
Level 3
Level 3
Hello - real quick question. Was pricing a switch and noticed that a switch designated as a fixed configuration model was considerably less that a a similiar switch that is a for lack of better terminology - non fixed configuration.
Can someone explain to me what exactly fixed configuration means when pertaining to a cisco switch or router.
Thanks in advance.
DH
Jon Marshall
Thanks in advance.
DH
For both switches and routers fixed configuration means that the device cannot have additional cards/modules added.
So for switches the 4500/6500/Nexus switches are modular because they take line cards/modules that are inserted into the chassis and you can choose which line cards you buy.
Fixed configuration switches don't have this capability so if you buy a 48 port switch such as the 3560 thats it. You can't then increase the number of ports in that switch. To get more ports you have to buy another switch.
Routers - pretty much the same. Fixed means what you get when you buy the device is all you will be able to have in terms of interfaces/modules etc.
Modular routers means that they have spare slots which you can populate with diffferent types of interface/modules (such VPN/IDS) depending on you
your needs.
Obviously modular devices allow for more scalability for future needs hence the additional cost.
Jon
Jon Marshall
Thanks in advance.
DH
your needs.
Jon
Thanks Jon - very helpful
DJ
