Ivan
I do not have a 3750 to check it on but there are several approaches that may work. The simplist is probably clear arp. Some versions of IOS have an enhancement that allows you to specify a particular interface on which to clear the arp cache. Or you might try clear ip arp which allows you to specify the particular IP address for which you want to clear the arp cache.
Rick
Rick
