compabality with rsp720 with Cisco 6509
san_dec21
Hi,all
Thanks in advance
cisco rsp 720 sup is compatible with 6509.please shower some light on this point.
RSP 720 is not supported on 6500s, its supported only on 7600 chassis.
Cisco 7600 chassis supports both - SUP 720 adn RSP 720.
-> Sushil
6 Replies 6
Joseph W. Doherty
From Table 7 in: http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8072579f.html
Supported chassis
Cisco 7603-S, 7604, 7606-S, 7609, and 7609-S models (Cisco 7606 and Cisco 7613 are not supported)
Hi,Joseph
Thanks for reply.
Link provide valuble informatiom about rsp720 sup.but i want know to that can i load rsp720 sup into 6500 series chasis?
Hi, Niranjan
Thanks for reply.
Finaly i can't insert RSP 720 sup into 6500 chasis.right?
"but i want know to that can i load rsp720 sup into 6500 series chasis?"
Understood, but the reference and the extracted information I provided, notes that only some 7600 chassis support the RSP720, which implies that none of the 6500s are supported, i.e. likely won't function.
-> Sushil
