Configuring a policer on a supervisior
Remko.vangilst
Dear all,
We created a policy-map to rate limit traffic on a RSP720-3C-10GE card.
Traffic must rate-limited to 5Gbit, but when we test it with 9Gbit all the traffic is allowed.
(we see the 9G leaving the router on an outgoing interface)
Can it be the case that rate-limiting traffic only is allowed on line cards?
https://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap7.html#wp1374297
I found some usefull information in the link above, but could not find anything about this.
Kind regards,
Remko van Gilst
Remko.vangilst
interface TenGigabitEthernet6/4
switchport
switchport access vlan 323
switchport mode dot1q-tunnel
load-interval 30
mls qos vlan-based
mls qos trust dscp
storm-control broadcast level 5.00
storm-control multicast level 5.00
l2protocol-tunnel cdp
l2protocol-tunnel stp
l2protocol-tunnel vtp
no cdp enable
spanning-tree bpdufilter enable
service-policy input 5000Mbps-Premium
end
I tested it with a basic configuration:
#sh policy-map 5000Mbps_temp
  Policy Map 5000Mbps_temp
    Class class-default
     police cir 5000000000 bc 156250000
       conform-action transmit
       exceed-action drop
I apllied the policy to the SVI, not working
I aplied the policy to the fysical interface, not working
I tried to match traffic with an access-list, not working (at first I matched without ACL)
The same policer works fine on a line card.
Please advise
