Configuring POE+ for a third party device
dariely_ann
I'm trying to configure a Cisco WS-C3650-24PS to power a Samsung display monitor using POE+. The monitor requires somewhere around 20W of power. The switch allows up to 30W. If I do a show power inline, I can see the interface drawing 25.5W but the monitor is not turning on. I have change the configuration to static power, auto power, I set up the power policing and I get no errors. Also, I have lldp enabled. I was using a 3750 for the monitors previously without issues. Could someone help me?
Julio E. Moisa
Not sure if it related to the image or hardware but usually the max Watt allowed is 15.4 per interface.
Try to verify on you device this:
interface f1/1
power inline static max ?
And verify the max mili watts allowed.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
The max allowed is 30W. PoE+ allows each of the interfaces to go up to 30. Initially, I was configuring the interface for static max 25000, because the device was only using 19400, but this morning I decided to change it to static max 30000 and it did the job. Thanks for the suggestion.
