Connectivity problem from the user network
rmrahman0302
I am having problem to  connecto from one network to another  network.My network setup is, I have 10.0.0.0network  on one side of the router and on the other side I have 192.168.0.0 network. The problem is user from 10.0.0.0 can not connect to 192.168.0.0 network. The router is directly connected to the 192.168.0.0 network and I don't have any access to that 192.168.0.0 network to make any changes on the networ but from the router I can ping any host on 192.168.0.0 network. On the 10.0.0.0 network I am using EIGRP. Anybody has any idea on this?
Peter Paluch
I assume that you have verified that your problem is not caused by any ACLs in place.
What does a traceroute or tracrt command say when you perform it from a host in the 10.0.0.0 network towards a station in the 192.168.0.0? Where does the traceroute stop?
Are the stations in both networks aware of the existence of the other network? In other words, do the routers in the 10.0.0.0 network know about the existence of the 192.168.0.0 network, and vice versa? It may be possible that either the routers are unable to route the packet from 10.0.0.0 to 192.168.0.0, or that the reply back from 192.168.0.0 cannot be routed to the original sender in the 10.0.0.0.
As you can ping all stations in 192.168.0.0 from the router itself, this seems to me to be a routing issue. Please verify that all routers in both your networks are aware of the existence of all networks.
Best regards,
Peter
