Core Switch reboot
sameermunj
Hi team
i am using Cat 4507 as core switch in the network..The switch has rebooted automatically and have not generated any related logs in syslog..i am putting down the capture of show version..this says last reload reason is abort at PC 0x0  ------------------ is this related to parity error.if you see we are running latest softwrae verstion and post reboot the line cards and Sup have passed the diagnostic test successfully.
------------------ show version ------------------
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 15.1(2)SG, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 05-Dec-12 05:38 by prod_rel_team
ROM: 12.2(44r)SG
INVKG5GFCR02 uptime is 21 minutes
Uptime for this control processor is 21 minutes
System returned to ROM by abort at PC 0x0
System restarted at 12:28:02 IST Wed Feb 20 2013
System image file is "bootflash:cat4500e-entservicesk9-mz.151-2.SG.bin"
Darkside Revision 4, Jawa Revision 18, Tatooine Revision 141, Forerunner Revision 1.83
Last reload reason: abort at PC 0x0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4507R-E (MPC8548) processor (revision 6) with 524288K bytes of memory.
Processor board ID
MPC8548 CPU at 1.33GHz, Supervisor 6-E
Last reset from System Crash
29 Virtual Ethernet interfaces
76 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
------------------ show diagnostic result module all detail ------------------
Current bootup diagnostic level: minimal
module 1:   SerialNo :
  Overall Diagnostic Result for module 1 : PASS
  Diagnostic level at card bootup: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
  ___________________________________________________________________________
    1) linecard-online-diag ------------> .
          Error code ------------------> 0 (DIAG_SUCCESS)
          Total run count -------------> 1
          Last test testing type ------> n/a
          Last test execution time ----> Feb 20 2013 12:28:57
          First test failure time -----> n/a
          Last test failure time ------> n/a
          Last test pass time ---------> Feb 20 2013 12:28:57
          Total failure count ---------> 0
          Consecutive failure count ---> 0
Slot Ports Card Type                              Diag Status      Diag Details
1    48   10/100/1000BaseT (RJ45)               Passed           None
Detailed Status
. = Pass              U = Unknown
L = Loopback failure  S = Stub failure
P = Port failure
E = SEEPROM failure   G = GBIC integrity check failure
Ports 1   2   3   4   5   6   7   8   9   10  11  12  13  14  15  16
Ports 17  18  19  20  21  22  23  24  25  26  27  28  29  30  31  32
Ports 33  34  35  36  37  38  39  40  41  42  43  44  45  46  47  48
    2) online-diag-tdr:
   Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
         U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U
   Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
          Error code ------------------> 3 (DIAG_SKIPPED)
          Total run count -------------> 0
          Last test execution time ----> n/a
          Last test pass time ---------> n/a
Detailed Status
module 2:   SerialNo
  Overall Diagnostic Result for module 2 : PASS
2    24   1000BaseX (SFP)                        Passed           None
Detailed Status
P = Port failure
    2) stub-rx-errors ------------------> .
          Total run count -------------> 21
          Last test testing type ------> Health Monitoring
          Last test execution time ----> Feb 20 2013 12:49:59
          Last test pass time ---------> Feb 20 2013 12:49:59
module 3:   SerialNo :
  Overall Diagnostic Result for module 3 : PASS
    1) supervisor-bootup ---------------> .
Power-On-Self-Test Results for ACTIVE Supervisor
prod: WS-X45-SUP6-E part: 73-10597-08 serial: JAE1238V9TJ
Power-on-self-test for Module 3: WS-X45-SUP6-E
CPU Subsystem Tests ...
seeprom: Pass
Traffic: L3 Looopback ...
Test Results: Pass
Traffic: L2 Loopback ...
Test Results: Pass
Switching Subsystem Memory ...
Packet Memory Test Results: Pass
Module 3 Passed
    2) linecard-online-diag ------------> .
3     6   Sup 6-E 10GE (X2), 1000BaseX (SFP)    Skipped          Packet memory
Detailed Status
P = Port failure
Ports 1   2   3   4   5   6
    3) stub-rx-errors ------------------> .
    4) supervisor-rx-errors ------------> .
please suggest..
Hi Sameer,
The crashed happen due to the Bug on the software. Currently you can monitor the device and plan for the software upgrade (Probably to 15.1(2)SG1.xx).
Inayath
*Plz reate the usefull post.
9 Replies 9
InayathUlla Sharieff
Hi Sameer,
Could you please provide the output of " show platform crashdump" ?
Inayath
hi
please find below the output
------------------ show platform crashdump ------------------
Current Time: 2/20/2013 12:50:4
Last Power Failure: 01/26/2013 02:14:24
Last Reload Status: 00002000
Last Software Reset State: 00000000
Crashdump version: 1
Last crash: 02/20/2013 12:26:01
Build: 15.1(2)SG ENTSERVICESK9
buildversion addr: 157D7DE4
========= Context ======================
pc=12EC6638 lr=128BFDD0 msr=02029230 vector=00000D00
cr=48022024 ctr=12EC6620 xer=00000000
r0=128BFDD0 r1=18568430 r2=0000001E r3=000000DE
r4=1E513B10 r5=0000000A r6=00000002 r7=00000007
r8=1DBB189E r9=00000000 r10=00000051 r11=24F474D8
r12=0810A9BD r13=D629FAF2 r14=24F466CC r15=14A621CC
r16=FE000000 r17=28000022 r18=1A09601C r19=00000039
r20=157E0000 r21=0000005F r22=0000000E r23=11952898
r24=18568690 r25=1E513B1E r26=185685D8 r27=24FA1DF8
r28=00000051 r29=0000000A r30=24F466CC r31=00000000
dec=00024FA2 tbu=00008397 tbl=F974FC02
dar=80210020 dsisr=80210020 hid0=80004000
Traceback: 12EC6638 128BFDD0 10332034 10334D48 103432A4 10341AB0 128F93FC 12ECB61C 1408F29C 14091020 14090758 12B5F9F0 12B5FDC4 128F3F18 128F4310 128F4A94 10B978D8 10B91C24
========= Stack frames ======================
Frame 1: pc=128BFDD0 stack=18568480
Frame 2: pc=10332034 stack=18568490
Frame 3: pc=10334D48 stack=185685A8
Frame 4: pc=103432A4 stack=185685D0
Frame 5: pc=10341AB0 stack=18568638
Frame 6: pc=128F93FC stack=18568640
Frame 7: pc=12ECB61C stack=18568680
Frame 8: pc=1408F29C stack=1856A020
Frame 9: pc=14091020 stack=1856A0A0
Frame 10: pc=14090758 stack=1856A0D0
Frame 11: pc=12B5F9F0 stack=1856A0D8
Frame 12: pc=12B5FDC4 stack=1856A0F0
Frame 13: pc=128F3F18 stack=1856A0F8
Frame 14: pc=128F4310 stack=1856A180
Frame 15: pc=128F4A94 stack=1856A1D0
Frame 16: pc=10B978D8 stack=1856A200
Frame 17: pc=10B91C24 stack=1856A208
========= Pushed stack ======================
18568430: 18568480 12EC6758 1DF27040 18568450
18568440: 00000001 0000003C 00000000 00000001
18568450: 00000000 000A0100 006AFA1C 24FA6A90
18568460: 00000042 02000001 24FA6A90 24FA1DF8
18568470: 00000051 24FA1DE8 24F466CC 1A09601C
18568480: 18568490 128BFDD0 0000000E 254F6E00
18568490: 185685A8 10332034 1AD06270 000C000C
185684A0: 00000000 00ED0100 FF40FFFE 00000003
185684B0: 24F466CC FFFFFFFF 185697E0 18D38034
185684C0: 185697E0 1ADEE2BC 1A97AEC8 18D38020
185684D0: 185684E0 12B56254 18D38020 1A94FE98
185684E0: 185684F8 12EE3074 00000016 1B6B2DF4
185684F0: 1A94FE98 18D38020 18568680 12EE35CC
18568500: 00000000 FFFFFFFF FFFF0000 00000000
18568510: 00000000 0000FFFF 18568520 FFFFFFFF
18568520: 18568528 13E60344 18568680 12ED42E0
18568530: 00000000 00000000 00000000 00000000
18568540: 00000051 185685E0 2414B648 00000000
18568550: 00000000 00000000 18568578 28000022
18568560: 128F4980 14A621CC FE000000 00000000
18568570: 1A953234 00000039 157E0000 0000005F
18568580: 24F466CC 11952898 18568690 24F466CC
18568590: 185685D8 1E513B1E 1A09601C 185685E0
185685A0: 2414B648 00009C96 185685D0 10334D48
185685B0: 00000000 00000001 00001000 00000000
185685C0: 00000000 00000000 00000000 1BAC8F80
185685D0: 18568638 103432A4 254F6E70 2549B780
185685E0: 00000001 12886F2C 18568608 12B7A728
185685F0: 128F4980 14A621CC FE000000 00000000
18568600: 1A953234 00000039 00000004 02000000
18568610: 00000000 0000000A 18568690 24F474D8
18568620: 00000000 00000001 00000800 00000000
18568630: 00000001 1A09601C 18568640 10341AB0
18568640: 18568680 128F93FC 1A953234 00000039
18568650: 00000004 02000000 00000000 184DD160
18568660: 00000004 1ACDEF5C 00000000 1E513A80
18568670: 28000024 0000000A 1A923234 0000000A
18568680: 1856A020 12ECB61C 12000000 00000000
18568690: 00000000 00000016 00000001 00000000
185686A0: 0000004E 002D1E7C 00000000 00107BAB
185686B0: 00000088 20007FFF 00000000 00000000
185686C0: 00000000 0010FFFF FFFFFFFF 0200005E
185686D0: 00018998 00000000 DC7B94D9 E9200010
185686E0: 7BAB996F 00107BAB 996F0010 7BAB996F
185686F0: 00107BAB 996F001A A0BDB2D6 00107BAB
18568700: 99320000 00000000 00000000 0010FFFF
18568710: FFFFFFFF 20007FFF 00000000 00000000
18568720: 00000000 00000000 00000000 00000000
18568730: 00000000 00000000 00000000 00000000
18568740: 00000000 00000000 00000000 00000000
18568750: 00000000 00000000 00000000 FFFFFFFF
18568760: FFFF0180 C2000010 18568790 0000FFFF
18568770: FFFFFFFF 01000CDD DDDDE411 5B5B2424
18568780: 00000000 1BA8B8C8 1AD07450 18568818
18568790: 185687F0 13E79A7C E4115B5B 24242424
185687A0: E4115B5B 24242424 1AD07450 1ACE44E0
185687B0: 0000000E 1AD48220 185687F0 13E62210
185687C0: E4115B5B 24248B68 E4115B5B 24248E74
185687D0: 1AD48220 000EE120 1AD11E20 18568818
185687E0: 1AD07450 18568B80 1AD48220 18569618
185687F0: 18568B28 12F2D9C0 E4115B5B 2424E411
18568800: 1856A118 1856A100 14A60DA4 18568B68
18568810: 0000003C 18568E74 18568BB0 18568870
18568820: 185688A8 18568870 00000000 18568840
18568830: 1A29177C 18568918 18568868 12C127A0
18568840: 18568868 00000F8F 00000000 00000000
18568850: 12C12728 1A29177C 00000000 1A0CAA44
18568860: 18568918 1A1416E8 18568900 12C13834
18568870: 000E000E 00000000 00000001 00000C07
18568880: AC0A0000 0C07AC0A 00000C07 AC0A0000
18568890: 0C07AC0A 00000000 00107BAB 99339090
185688A0: 20007FFF 0000FFFF FFFFFFFF FFFFFFFF
185688B0: FFFFFFFF FFFFFFFF 99338A40 20007FFF
185688C0: 000088F0 00000000 005688F0 00000000
185688D0: 00107BAB 99330000 20007FFF 00000000
185688E0: 185688F8 18568980 1856896C 1856000A
185688F0: 1A0CAA44 18568930 1A0D16D8 18568A78
18568900: 18568928 12C138E4 00000F8F 00000000
18568910: 18568928 00000000 00000F8F 18568930
18568920: 1A0CAA44 00107BAB 996F0010 7BAB996F
18568930: 00107BAB 996F0010 7BAB996F 00107BAB
18568940: 996F0010 7BAB996F 001AA0BD B2D6001A
18568950: A0BDB2D6 001AA0BD B2D65B5B 24240000
18568960: 20004058 00000000 00000000 FFFFFFFF
18568970: FFFFFFFF FFFFFFFF FFFFFFFF FFFF0100
18568980: 0CCCCCCD 01000CCC CCCC9618 0000F8F0
18568990: 18568B28 00000001 185689A0 0000F8F0
185689A0: E4115B5B 2424DEE0 20004058 20004058
185689B0: 14A60DA4 18568B7C 18568A60 1856E411
185689C0: 5B5B2424 E4115B5B 242489E8 1A0D16D8
185689D0: 18568A7C 18568A58 18568A40 00000003
185689E0: 18568A30 000E000E 00000000 00000001
185689F0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
18568A00: FFFF5B5B 2424000E 00000058 0000FFFF
18568A10: FFFFFFFF FFFFFFFF FFFF0001 18568B68
18568A20: 18568A70 18568AEC 18568A64 1A0CAA44
18568A30: 18568A60 12C10D14 00000000 1ABD2CA0
18568A40: 001D090A DC19000E 00000058 1A0CAA44
18568A50: 18568A70 18568AC0 000B0000 1AC66B60
18568A60: 1AC66B60 18568AC0 1A0CA1C0 0000000B
18568A70: 18568A80 12BD4BA0 000B0000 1AC66B60
18568A80: 18568B28 12BCC578 20004060 20004060
18568A90: 001D090A DC19001D 090ADC19 001D090A
18568AA0: DC19FFFF 20004060 00000FF9 00000000
18568AB0: 00000000 00000001 1A0C9494 1A3D4328
18568AC0: 001D090A DC19F2E8 00000001 00000FF9
18568AD0: 000B0000 1AC66B60 00000000 00000001
18568AE0: 128F4980 14A621CC 14A62198 18568B40
18568AF0: 1856A118 1856A100 14A60DA4 18568B68
18568B00: 000001F9 18568E74 157E0000 1ABCE568
18568B10: 00000001 0000FF94 18568B58 18568B80
18568B20: 1A0C9494 00000000 18569DF8 12BD3F30
18568B30: 60008024 00000000 00000000 00000000
18568B40: 00107BAB 99330000 0000FFFF FFFFFFFF
18568B50: FFFF0024 0000FFFF 00000000 0000FFFF
18568B60: FF000000 00000000 000B000B 00000000
18568B70: 00000001 001D090A DC199A28 20004060
18568B80: E4115B5B 2424000E 00568BB8 1AC64A60
18568B90: 01FFFFFF 00000001 000E000E 00000000
18568BA0: 00000001 E4115B5B 24249B40 20004058
18568BB0: 00000000 00000000 18568840 1A29177C
18568BC0: 18568918 18568868 12C127A0 18568868
18568BD0: 00000080 00088879 00000080 00088879
18568BE0: 00000000 00000000 00000000 00000000
18568BF0: 00000000 00000000 00000080 0000197C
18568C00: 00000000 00000000 00000000 00000000
18568C10: 00000080 00088879 00000000 00000000
18568C20: 00000000 00000000 00000000 00000000
18568C30: 00000000 00000000 00000000 00000000
18568C40: 00000000 00000000 00000000 00000000
18568C50: 00000000 00000000 00000000 0000FFFF
18568C60: FFFFFFFF FFFF0000 00000000 00000000
18568C70: 80000063 81611E83 00800008 8879000A
18568C80: 00000000 00000000 00000000 00000000
18568C90: 00000000 00000000 00000000 00000000
18568CA0: 00000000 00000000 00000000 00000000
18568CB0: 00000000 00000000 00000000 00000000
18568CC0: 00000000 00000000 00000000 00000000
18568CD0: 00000000 00000000 00000000 00000000
18568CE0: 00000000 00000000 00000000 00000000
18568CF0: 00000000 00000000 0000FFFF 00000000
18568D00: FF020000 00000000 00000000 00010003
18568D10: 18568E74 18569618 00000001 DC7B94D9
18568D20: E9200002 00000000 00000001 00000000
18568D30: 00000000 00000000 00000000 00000000
18568D40: 00000000 00000000 00000000 00000000
18568D50: 00000000 00000000 00000000 00000000
18568D60: 00000000 00000000 00000000 00000000
18568D70: 00000000 00000000 00000000 00000000
18568D80: 00000000 00000000 00000000 00000000
18568D90: 00000000 00000000 00000000 00000000
18568DA0: 00000000 00000000 00000000 00000000
18568DB0: 00000000 00000000 00000000 0000FFFF
18568DC0: 00000000 00000000 1ABD2CA0 00000000
18568DD0: 00000000 00000000 00000000 00000000
18568DE0: 00000000 00000000 00000000 00000000
18568DF0: 00000000 00000000 00000000 00000000
18568E00: 00000000 00000000 00000000 00000000
18568E10: 00000000 00000000 00000000 00000000
18568E20: 00000000 00000000 00000000 00000000
18568E30: 00000000 00000000 00000000 00000000
18568E40: 00000000 00000000 00000000 00000000
18568E50: 001AA0BD B2D6000C 00000000 1AC66B60
18568E60: 01000000 00000001 00000001 128F4980
18568E70: 14A621CC 00000001 00000000 00000000
18568E80: 00000000 18568840 1A29177C 18568918
18568E90: 18568868 12C127A0 18568868 00000000
18568EA0: 00000000 00000000 00000000 00000000
18568EB0: 00000000 00000000 00000000 00000000
18568EC0: 00000000 00000000 00000000 00000000
18568ED0: 00000000 00000000 00000000 00000000
18568EE0: 00000000 00000000 00000000 00000000
18568EF0: 00000000 00000000 00000000 00000000
18568F00: 00000000 00000000 00000000 00000000
18568F10: 00000000 00000000 00000000 00000000
18568F20: 00000000 00000000 0000FFFF 00000000
18568F30: 00000000 00000000 00000000 00000000
18568F40: 00000000 00000000 00000000 00000000
18568F50: 00000000 00000000 00000000 00000000
18568F60: 00000000 00000000 00000000 00000000
18568F70: 00000000 00000000 00000000 00000000
18568F80: 00000000 00000000 00000000 00000000
18568F90: 00000000 00000000 00000000 00000000
18568FA0: 00000000 00000000 00000000 00000000
18568FB0: 00000000 00000000 00000000 00000000
18568FC0: 00000000 0000FFFF 00000000 00000000
18568FD0: 18568BB0 18569618 00000001 18568E74
18568FE0: 18569618 00000001 DC7B94D9 E9200002
18568FF0: 00000000 00000003 1AB68330 1AD06270
18569000: 000C000C 00000000 00ED0100 FF40FFFE
18569010: 00000003 00000000 00000003 1AB68330
18569020: 1AD06270 000C000C 00000000 00ED0100
18569030: FF40FFFE 00000003 00000000 00000003
18569040: 1AB68330 1AD06270 000C000C 00000000
18569050: 00ED0100 FF40FFFE 00000003 00000000
18569060: 00000000 00000000 00000000 00000000
18569070: 00000000 00000000 00000000 00000000
18569080: 00000000 00000000 0000FFFF 00000000
18569090: 00000000 1ABD2CA0 00000000 00000000
185690A0: 00000000 00000000 00000000 00000000
185690B0: 00000000 00000000 00000000 00000000
185690C0: 00000000 00000000 00000000 00000000
185690D0: 00000000 00000000 00000000 00000000
185690E0: 00000000 00000000 00000000 00000000
185690F0: 00000000 00000000 00000000 00000000
18569100: 00000000 00000000 00000000 00000000
18569110: 00000000 00000000 00000000 00000000
18569120: 00000000 0000FFFF 00000000 00000000
18569130: 00000000 00000001 128F4980 14A621CC
18569140: 00000000 00000000 00000000 00000000
18569150: 00000000 00000000 00000000 00000000
18569160: 00000000 00000000 00000000 00000000
18569170: 00000000 00000000 00000000 00000000
18569180: 00000000 00000000 001AA0BD B2D6000C
18569190: 00000000 1AC66B60 01000000 00000001
185691A0: FFFFFFFF FFFF000C 00010000 00000001
185691B0: 00000000 00000000 00000000 00000000
185691C0: 00000000 00000000 00000000 00000000
185691D0: 00000000 00000000 00000000 00000000
185691E0: 00000000 00000000 00000000 0000FFFF
185691F0: 00000000 00000000 00000000 00000000
18569200: 00000000 00000000 00000000 00000000
18569210: 00000000 00000000 00000000 00000000
18569220: 00000000 00000000 00000000 00000000
18569230: 00000000 00000000 00000000 00000000
18569240: 00000000 00000000 00000000 00000000
18569250: 00000000 00000000 00000000 00000000
18569260: 00000000 00000000 00000000 00000000
18569270: 00000000 00000000 00000000 00000000
18569280: 00000000 00000000 0000FFFF 00000000
18569290: 00000000 00000000 00000000 00000000
185692A0: 00000000 18569A58 00000000 00000000
185692B0: 00000000 18569E60 00000000 00000000
185692C0: 00000000 00000000 00000000 00000000
185692D0: 00000000 00000000 00000000 00000000
185692E0: 00000000 00000000 00000000 00000000
185692F0: 00000000 00000000 00000000 00000000
18569300: 00000000 00000000 00000000 00000000
18569310: 00000000 00000000 00000000 00000000
18569320: 00000000 00000000 00000000 00000000
18569330: 00000000 00000000 00000000 00000000
18569340: 00000000 00000000 00000000 0000FFFF
18569350: 00000000 00000000 00000000 00000000
18569360: 00000000 00000000 00000000 00000000
18569370: 00000000 00000000 00000000 00000000
18569380: 00000000 00000000 00000000 00000000
18569390: 00000000 00000000 00000000 00000000
185693A0: 00000000 00000000 00000000 00000000
185693B0: 00000000 00000000 00000000 00000000
185693C0: 00000000 00000000 00000000 00000000
185693D0: 00000000 00000000 00000000 00000000
185693E0: 00000000 00000000 0000FFFF 00000000
185693F0: 00000000 00000000 00000000 00000000
18569400: 00000000 00000000 00000000 00000000
18569410: 00000000 00000000 00000000 00000000
18569420: 00000000 00000000 00000000 00000000
========= Popped stack ======================
18568230: 00000000 00000000 00000000 00000000
18568240: 00000000 00000000 00000000 00000000
18568250: 00000000 00000000 00000000 00000000
18568260: 00000000 00000000 00000000 00000000
18568270: 00000000 00000000 00000000 00000000
18568280: 00000000 00000000 00000000 00000000
18568290: 00000000 00000000 00000000 00000000
185682A0: 00000000 00000000 185682B8 00000000
185682B0: 23EB5AB4 00000000 185682E0 121BAA48
185682C0: 0000009C 00000096 185682D0 00000002
185682D0: 185682D8 13E60344 18568430 12ED4120
185682E0: 18568308 121BB860 18568308 00000000
185682F0: 00000068 00000002 18568308 00000002
18568300: 00000000 23EB5964 18568328 12204C1C
18568310: 18568320 00000001 173A4DE8 1D700CDC
18568320: 18568328 10B8ED14 18568348 12204DDC
18568330: 18568348 000000FF 1DD2DA32 00001D4C
18568340: 196AFA1C 173A4DE8 18568358 12206094
18568350: 18568368 196AFA1C 18568368 00001D4C
18568360: 1DD2DA32 196AFA1C 185683D0 1146C888
18568370: 00000000 00000000 01040000 9C9668FF
18568380: 00000000 00000000 00000000 00000000
18568390: 00000000 00000000 00000000 00000000
185683A0: 00000014 10000000 00000000 0000000C
185683B0: 185683B8 18D38020 185683C0 12BC80C4
185683C0: 185683E0 12B7D188 000011FF 196AFA1C
185683D0: 1BAC9FA0 23791F40 23794DC0 00002E80
185683E0: 18568430 12B7B5C0 000A8418 103B04E0
185683F0: 00000042 02000001 28022022 00000039
18568400: 157E0000 00000090 0000000E 11952898
18568410: 18568690 1DF270DE 185685D8 00000002
18568420: 18568454 00000000 1A923234 1DF27040
Hi Sameer,
Inayath
Thanks for your quick reply..can you please let me know the bug id for the same.i have tried checking the open caveats in this release but couldnt match any for this behaviour..is 15.1(2)SG1.xx is GA because on the site i can see the software currently installed in the switch as the latest one..
yesterday i have similar automatic reboot on another core (today it was core2 and yesterday it was core1)..i am putiing down the crashdump for that switch..can you please verify it is related to same bug...
Current Time: 2/19/2013 16:22:7
Last Power Failure: 01/26/2013 04:13:52
Last crash: 02/19/2013 13:11:53
pc=12ECAF50 lr=12ECAF44 msr=02029230 vector=00000D00
cr=42000042 ctr=1296AE70 xer=00000000
r0=12ECAF44 r1=1844BF78 r2=0000001E r3=1E9EC640
r4=00000002 r5=1E9EC6C0 r6=00000000 r7=00000000
r8=1BAC9EA0 r9=00000050 r10=00000000 r11=0E9EC6C7
r12=42000048 r13=DF7233CB r14=128F4980 r15=14A621CC
r16=F0000000 r17=00000000 r18=1844DA10 r19=0000003C
r20=00000014 r21=10000000 r22=00000000 r23=183C0A58
r24=00000004 r25=183B6DDC r26=00000000 r27=1E9EC640
r28=1A94FBD0 r29=1D9884B8 r30=1A923234 r31=1D988584
dec=00039270 tbu=00007D6E tbl=3A7DA5CF
Traceback: 12ECAF50 1408F29C 14091020 14090758 12B5F9F0 12B5FDC4 128F3F18 128F4310 128F4A94 10B978D8 10B91C24
Frame 1: pc=1408F29C stack=1844D918
Frame 2: pc=14091020 stack=1844D998
Frame 3: pc=14090758 stack=1844D9C8
Frame 4: pc=12B5F9F0 stack=1844D9D0
Frame 5: pc=12B5FDC4 stack=1844D9E8
Frame 6: pc=128F3F18 stack=1844D9F0
Frame 7: pc=128F4310 stack=1844DA78
Frame 8: pc=128F4A94 stack=1844DAC8
Frame 9: pc=10B978D8 stack=1844DAF8
Frame 10: pc=10B91C24 stack=1844DB00
1844BF70:                   1844D918 12ECAF44
1844BF80: 11000000 00000000 00000000 00000016
1844BF90: 00000001 00000000 0000004E 00000000
1844BFA0: 00000000 00000000 00000001 00000000
1844BFB0: 00000000 00000000 00000000 0000FFFF
1844BFC0: FFFFFFFF 0200005E 00010000 00000000
1844BFD0: 00000000 00000010 7BAB996F 00107BAB
1844BFE0: 996F0010 7BAB996F 00107BAB 996F001D
1844BFF0: 0919B097 00107BAB 99320000 00000000
1844C000: 00000016 1844FFFF FFFFFFFF 00000000
1844C010: 00000000 00000000 00000000 00000000
1844C020: 00000000 00000000 00000000 00000000
1844C030: 00000000 00000000 00000000 00000000
1844C040: 00000000 00000000 00000000 00000000
1844C050: 00000000 FFFFFFFF FFFF0180 C2000010
1844C060: 00000000 0000FFFF FFFFFFFF 01000CDD
1844C070: DDDD0000 00000000 00000000 00000000
1844C080: 00000000 00000000 00000000 00000000
1844C090: 00000000 00000000 0000FFFF 00000000
1844C0A0: 00000000 1E5BB99E 00000000 00000000
1844C0B0: 00000000 00000000 00000000 00000000
1844C0C0: 00000000 00000000 00000000 00000000
1844C0D0: 00000000 00000000 00000000 00000000
1844C0E0: 00000000 00000000 00000000 00000000
1844C0F0: 00000000 00000000 00000000 00000000
1844C100: 00000000 00000000 00000000 00000000
1844C110: 00000000 00000000 00000000 00000000
1844C120: 00000000 00000000 00000000 00000000
1844C130: 00000000 0000FFFF 00000000 00000000
1844C140: 24FDF028 15BC0B10 00000007 00000007
1844C150: 00000001 00000000 00000001 01000CCC
1844C160: CCCE0001 00000000 00000009 00000000
1844C170: 00000001 00000C07 AC0E0000 0C07AC0E
1844C180: 00000C07 AC0E0000 0C07AC0E 00000000
1844C190: 00000000 00000000 00000000 0000FFFF
1844C1A0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1844C1B0: 00000000 00000000 00000000 00000000
1844C1C0: 00000000 00000000 00000000 00000000
1844C1D0: 00000000 00000000 00000000 00000000
1844C1E0: 00000000 00000022 00000000 00000000
1844C1F0: 00000000 00000000 00000000 00000000
1844C200: 00000000 00040050 1ABD2CA0 00000000
1844C210: FFFF0000 00000000 00000000 00107BAB
1844C220: 996F0010 7BAB996F 00107BAB 996F0010
1844C230: 7BAB996F 00107BAB 996F0010 7BAB996F
1844C240: 001D0919 B097001D 0919B097 001D0919
1844C250: B0970000 00000000 00000000 00000000
1844C260: 00000000 FFFFFFFF FFFFFFFF FFFFFFFF
1844C270: FFFFFFFF FFFF0100 0CCCCCCD 01000CCC
1844C280: CCCC0000 00000000 00000000 00000000
1844C290: 00000000 00000000 00000000 00000000
1844C2A0: 0000FFFF 00000000 00000000 0000EEC0
1844C2B0: 00000000 00000640 00000000 00000000
1844C2C0: 00000014 10000000 00000000 00000016
1844C2D0: 1844D0D8 1AC64A60 00000000 00000000
1844C2E0: 00000000 00000000 FFFFFFFF FFFFFFFF
1844C2F0: FFFFFFFF FFFFFFFF FFFF0000 00000000
1844C300: 00000000 0000FFFF FFFFFFFF FFFFFFFF
1844C310: FFFF0000 00000000 00000000 00000000
1844C320: 00000000 00000000 00000000 00000000
1844C330: 00000000 00000000 00000000 00000000
1844C340: 00000000 00000000 00000000 00000000
1844C350: 00000000 00000000 00000000 00000000
1844C360: 00000000 0000FFFF 00000000 00000000
1844C370: 1E5BB99E 00000000 00000000 00000000
1844C380: 00000000 00000000 00000000 00000000
1844C390: 00000000 00000000 00000000 00000000
1844C3A0: 00000000 00000000 00000000 00000000
1844C3B0: 00000000 00000000 00000000 00000000
1844C3C0: 00000000 00000000 00000000 00000000
1844C3D0: 00000000 00000000 00000000 00000000
1844C3E0: 00000000 00000000 00000000 00000000
1844C3F0: 00000000 00000000 00000000 00000000
1844C400: 0000FFFF 00000000 00000000 24FDF028
1844C410: 15BC0B10 00000007 00000007 00000000
1844C420: 00090064 00080065 00070066 00060067
1844C430: 000B0001 00000000 00000000 00000000
1844C440: 00000000 00000000 00000000 00000000
1844C450: 00000000 00000000 00000000 00000000
1844C460: 00000000 00000000 00000000 00000000
1844C470: 00000000 00000000 00000000 00000000
1844C480: 00000000 00000000 00000000 00000000
1844C490: 00000000 00000000 00000000 00000000
1844C4A0: 00000000 00000000 00000000 00000000
1844C4B0: 00000000 00000000 00000000 00000000
1844C4C0: 00000000 00000000 00000080 0000187C
1844C4D0: 00000080 0008087C 00000000 00000000
1844C4E0: 00000000 00000000 00000000 00000000
1844C4F0: 00000080 0000187C 00000000 00000000
1844C500: 00000000 00000000 00000080 0000187C
1844C510: 00000000 00000000 00000000 00000000
1844C520: 00000000 00000000 00000000 00000000
1844C530: 00000000 00000000 00000000 00000000
1844C540: 00000000 00000000 00000000 00000000
1844C550: 00000000 00000000 FFFFFFFF FFFF0000
1844C560: 00000000 0000FFFF 80000060 7B51E763
1844C570: 00800000 187C0022 0004C5A8 0021BBA4
1844C580: 00000000 00000000 0004C5A0 00000000
1844C590: 0004C5A8 00000004 003F0000 00000000
1844C5A0: 00000000 00000000 00000000 00000000
1844C5B0: 00000000 00000000 00000000 00000000
1844C5C0: 00000000 00000000 00000000 00000000
1844C5D0: 00000000 00000000 00000000 00000000
1844C5E0: 00000000 00000000 00000000 00000000
1844C5F0: 00000000 00000000 FF020000 00000000
1844C600: 00000000 00010002 00000000 00000000
1844C610: 00000000 00000000 00000000 00000000
1844C620: 00000000 00000000 0000FFFF 00000000
1844C630: 00000000 FFFFFFFF 00000000 00000000
1844C640: 00000000 00000000 00000000 00000000
1844C650: 1844C680 00000000 00000001 01C6E41C
1844C660: 00000004 00000000 1844CE68 1844CE58
1844C670: 1844C688 1A4941E0 157E0000 234A6B00
1844C680: 1844CE50 12C6E41C 01000000 00000000
1844C690: 3D080000 00000000 00000001 01C6E41C
1844C6A0: 00000086 00000000 0000F800 01000000
1844C6B0: 00000000 00000000 00000001 01C6E41C
1844C6C0: 00000087 00000000 0000F801 01000000
1844C6D0: 00000000 00000000 00000001 01C6E41C
1844C6E0: 00000002 00000000 0000F802 01000000
1844C6F0: 00000000 000542C5 00000001 01C6E41C
1844C700: 00000030 00000000 0000F803 01000000
1844C710: 00000000 000542BB 00000001 01C6E41C
1844C720: 00000045 00000000 0000F804 01000000
1844C730: 00000000 00000000 00000001 01C6E41C
1844C740: 00000046 00000000 001D0919 B0970022
1844C750: 0044CA90 1AC64A60 0144CA98 00000001
1844C760: 00000004 00000000 0000F806 01000000
1844C770: 00000000 000542BD 00000001 01C6E41C
1844C780: 00000047 00000000 0000FFFF 01000000
1844C790: 00000000 00000000 00000003 07000000
1844C7A0: 00000000 00000002 FFFFFFFF 00000000
1844C7B0: 00000000 00000000 00000003 07000000
1844C7C0: 00000000 00000002 FFFFFFFF 00000000
1844C7D0: 00000000 00000000 00000003 07000000
1844C7E0: 00000000 00000002 FFFFFFFF 00000000
1844C7F0: 00000000 00000000 00000003 07000000
1844C800: 00000000 00000002 FFFFFFFF 00000000
1844C810: 00000000 00000000 00000003 07000000
1844C820: 00000000 00000002 FFFFFFFF 00000000
1844C830: 00000000 00000000 00000003 07000000
1844C840: 00000000 00000002 FFFFFFFF 00000000
1844C850: 00000000 00000000 00000003 07000000
1844C860: 00000000 00000002 FFFFFFFF 00000000
1844C870: 00000000 00000000 00000003 07000000
1844C880: 00000000 00000002 FFFFFFFF 00000000
1844C890: 00000000 00000000 00000003 07000000
1844C8A0: 00000000 00000002 FFFFFFFF 00000000
1844C8B0: 00000000 00000000 00000003 07000000
1844C8C0: 00000000 00000002 FFFFFFFF 00000000
1844C8D0: 00000000 00000000 00000003 07000000
1844C8E0: 00000000 00000002 FFFFFFFF 00000003
1844C8F0: 1AB648F0 1AD0E880 00220022 00000000
1844C900: 00ED0100 FF40FFFE 00000003 00000000
1844C910: 00000003 1AB648F0 1AD0E880 00220022
1844C920: 00000000 00ED0100 FF40FFFE 00000003
1844C930: 00000000 00000003 1AB648F0 1AD0E880
1844C940: 00220022 00000000 00ED0100 FF40FFFE
1844C950: 00000003 00000000 00000003 07000000
1844C960: 00000000 00000002 FFFFFFFF 00000000
1844C970: 00000000 00000000 00000003 07000000
1844C980: 00000000 00000002 FFFFFFFF 00000000
1844C990: 00000000 00000000 00000003 07000000
1844C9A0: 00000000 00000002 FFFFFFFF 00000000
1844C9B0: 00000000 00000000 00000003 07000000
1844C9C0: 00000000 00000002 FFFFFFFF 00000000
1844C9D0: 00000000 00000000 00000003 07000000
1844C9E0: 00000000 00000002 FFFFFFFF 00000000
1844C9F0: 00000000 00000000 00000003 07000000
1844CA00: 00000000 00000002 FFFFFFFF 00000000
1844CA10: 00000000 00000000 00000003 07000000
1844CA20: 00000000 00000002 FFFFFFFF 00000000
1844CA30: 00000000 00000000 00000003 07000000
1844CA40: 00000000 00000002 FFFFFFFF 00000000
1844CA50: 00000000 00000000 00000003 07000000
1844CA60: 00000000 00000002 FFFFFFFF 00000000
1844CA70: 00000000 00000000 00000003 07000000
1844CA80: 001D0919 B0970022 0044CA90 1AC64A60
1844CA90: 0144CA98 00000001 FFFFFFFF FFFF0022
1844CAA0: 000100FF 00000001 00AC9FE0 2379BFE0
1844CAB0: 237A1070 00005090 1844CB08 12B7B5C0
1844CAC0: E0010000 00000002 00002200 1C100000
1844CAD0: 24022042 14B36EE8 0000002A 1A9504B0
1844CAE0: 157E0000 1844CB10 1844CD14 00000000
1844CAF0: 1844CB08 00000000 1C056020 00000001
1844CB00: 1C350020 18D38020 1844CC50 12EBD8C8
1844CB10: 00000000 00000000 00000000 996F0100
1844CB20: 0CCDCDD0 00107BAB 996F0010 7BAB996F
1844CB30: 00107BAB 996F0010 7BAB996F 00107BAB
1844CB40: 996F0010 7BAB996F 00107BAB 996F0010
1844CB50: 7BAB996F 00107BAB 996F0003 07000000
1844CB60: 00002200 1C100000 FFFFFFFF 00000000
1844CB70: 00000000 00000000 00000003 07000000
1844CB80: 00000000 00000002 FFFFFFFF 00000000
1844CB90: 00000000 00000000 00000003 07000000
1844CBA0: 00000000 00000002 FFFFFFFF 00000000
1844CBB0: 00000000 00000000 00000003 07000000
1844CBC0: 00000000 00000002 FFFFFFFF 00000000
1844CBD0: 00000000 00000000 00000003 07000000
1844CBE0: 00000000 00000002 FFFFFFFF 00000000
1844CBF0: 00000000 00000000 00000003 07000000
1844CC00: 00000000 44002042 18D02F84 18D02F83
1844CC10: 1844CC20 18D02F81 1C350020 1A9504B0
1844CC20: 1844CC38 12EBAA3C 1844CC38 1C350020
1844CC30: 1A9504B0 1844CD14 1844CC50 12EBAAA8
1844CC40: 1C056020 00000000 18D02F80 1844CD28
1844CC50: 1844CF40 12EBE078 00000003 07000000
1844CC60: 00000000 00000002 FFFFFFFF 00000000
1844CC70: 00000000 00000000 00000003 07000000
1844CC80: 00000000 00000002 FFFFFFFF 00000000
1844CC90: 00000000 00000000 00000003 07000000
1844CCA0: 00000000 00000002 FFFFFFFF 00000000
1844CCB0: 00000000 00000000 1844CF40 07000000
1844CCC0: 00000000 00000002 FFFFFFFF 00000000
1844CCD0: 00000000 00000000 00000003 07000000
1844CCE0: 00000000 00000002 FFFFFFFF 00000000
1844CCF0: 00000000 00000000 00000003 07000000
1844CD00: 00000000 00000002 FFFFFFFF 00000000
1844CD10: 00000000 00000000 00000000 00000001
1844CD20: 00000001 00000000 00000001 1AB241A8
1844CD30: 1AD00020 FFFF0001 00000000 FF000100
1844CD40: FF40FF00 00000003 0000FFFF 01010101
1844CD50: 01010000 00000000 00000000 FFFF0000
1844CD60: 00000000 00000000 00000000 00000000
1844CD70: 00000000 00000000 00000003 07000000
1844CD80: 00000000 00000002 FFFFFFFF 00000000
1844CD90: 00000000 00000000 00000003 07000000
1844CDA0: 00000000 00000002 FFFFFFFF 00000000
1844CDB0: 00000000 00000000 1844CF40 07000000
1844CDC0: 00000000 00000002 FFFFFFFF 00000000
1844CDD0: 00000000 00000000 1844CDE0 07000000
1844CDE0: 1844CDE8 13E60344 1844CF40 12ED4120
1844CDF0: 00000000 00000000 00000003 07000000
1844CE00: 00000000 00000002 FFFFFFFF 00000000
1844CE10: 00000000 00000000 00000003 07000000
1844CE20: 00000000 00000002 FFFFFFFF 00000000
1844CE30: 1844CF28 00000000 1844CE68 234A6B00
1844CE40: 157E0000 1844CE88 157E0000 234A6B00
1844CE50: 1844D660 12C77FF8 1844CE70 01C6E41C
1844CE60: 00000004 0000003A 1844CE70 1713291C
1844CE70: 1844CE80 14099D9C 1F294B14 1844CED8
1844CE80: 1844CE90 133C4680 01000000 1844CED8
1844CE90: 1844CEC8 12E5A2BC 00000001 01C6E41C
1844CEA0: 00000086 00000000 0000F800 01000000
1844CEB0: 1844CF40 00000000 00000001 1F2CCF50
1844CEC0: 1F2CC6CC 1844D200 1844CF08 12E62CA4
1844CED0: 1844CEE8 00000001 1AB241A8 1AD00020
1844CEE0: 18D02F85 18D02F86 18D02F88 18D02F8A
1844CEF0: 00000003 24000042 1844CF38 14A621CC
1844CF00: 1844CF40 1844DA20 1844D938 000001E1
1844CF10: A742C908 15DC7BA8 1844D918 157E0000
1844CF20: 1A94FB48 1F4D88BC 1A953234 1844D408
1844CF30: 18D38020 1844D5B0 1844CF40 12C96004
1844CF40: 1844D7E0 12ED28DC 0000F805 01000000
1844CF50: 00000000 00000000 00000001 01C6E41C
1844CF60: 00000000 00000000 1844CFF0 01000000
1844CF70: 00000000 00000000
1844BD70:                   FFFFFFFF FFFFFFFF
1844BD80: FFFFFFFF FFFFFFFF 00000003 1AB648F0
1844BD90: 1AD0E880 00220022 00000000 00ED0100
1844BDA0: FF40FFFE 00000003 0000FFFF FFFFFFFF
1844BDB0: 1844D0D8 18D38034 1844D0D8 1ADEE2BC
1844BDC0: 1A97AEC8 18D38020 1844BDD8 12B56254
1844BDD0: 18D38020 1A94FE98 1844BDF0 12EE3074
1844BDE0: 00000016 1B6B2DF4 1A94FE98 18D38020
1844BDF0: 1844BF78 12EE35CC 00000000 FFFFFFFF
1844BE00: FFFF0100 5E00000A 00000000 0000FFFF
1844BE10: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1844BE20: 1844BF78 12ED42E0 5E00000A 00000000
1844BE30: 00000000 00000000 00000000 00000000
1844BE40: 00000000 00000000 00000000 00000000
1844BE50: 1844BE70 00000000 00000000 22000042
1844BE60: 22000044 1873B750 1A923234 1E929E80
1844BE70: 1844BE78 12B720CC 1844BF70 12B71350
1844BE80: 00000000 00000000 00000000 00000000
1844BE90: 1844BEA0 00000000 1874E434 1BAC8F80
1844BEA0: 1844BEA8 128FB04C 1844BEC8 12B60634
1844BEB0: 1844BED8 00000000 00000000 1D9884B8
1844BEC0: 1BAC8F80 1BAC8F80 1844BED0 1296AE9C
1844BED0: 1844BF00 12B7A5CC 1844BEE0 00000000
1844BEE0: 1844BF00 12B7A728 00000000 0000003C
1844BEF0: 1A94FBD0 1D9884B8 1A923234 1BAC8F80
1844BF00: 1844BF78 12B7A810 0E9EC6C7 0E9EC6C7
1844BF10: 1844BF20 13EDF1DC 1E929F10 FFFF0200
1844BF20: 1844BF78 13EDF1DC FFFFFFFF 42000048
1844BF30: 128F4980 14A621CC F0000000 00000000
1844BF40: 1844DA10 0000003C 00000014 10000000
1844BF50: 00000000 183C0A58 00000004 183B6DDC
1844BF60: 00000000 00000000 1A94FBD0 1D9884B8
1844BF70: 1A923234 1D988584
Hi Sameer,
I decoded this trace and found the bug for this as well. I am sorry to say that the bug is internal to cisco and cannot be shared publically.
Kindly raise the TAC case if you want to get more details on this.
Inayath
* Plz rate if this helpfull.
is the version you have suggested is available for use on cisco site...i could see the latest ios as
151-2.SG.bin which is currently installed in my switch..Any idea when it will be available for general use..
Hi ,
I dont have timeframe as of now when it will be published.  Treat this crashed as transient which happens only once if in case if it crashed again kindly get back to us.
Inayath.
Hi Inayat
Looks like final queries from my side
==Are both the crashes (Core 1& Core2 )showing the same behaviours.
==As you mentioned its transient kind of issue,is it something similar to what happened with Soft/Hard Parity.
As you mentioned in your initial post,we will wait for the latest sw for the upgarde to resolve this permanently...
Hi Sameer,
Can you provide us the outputs of :
'show logging onboard uptime continuous'
 'show logging onboard message continuous'
Inayath
