Core Switch Replacement Recommendation
bcapiral
Please help me. We are using Cisco Catalyst 3750 as a core switch. Any suggestion what would be the model if we will replace it? Thank you!
Leo Laohoo
You will need to provide us with more useful information other than this.
  • What is your budget?
  • How many ports do you need?  Copper, Fibre Optic?
  • PoE
  • Speed needed?  100 Mbps (or slower), 1-, 10-, 25-, 40-, 100 Gbps?
  • Layer 2 or Layer 3?
  • If Layer 3, what routing protocols are you using?
  • What is your budget? Tight budget
  • How many ports do you need?  24 Ports, Copper
  • Speed needed?  Same with the 3750 Gig interface
  • Layer 2 or Layer 3? Multi layer
  • If Layer 3, what routing protocols are you using? OSPF and Static Routing
Catalyst 9200/9200L is the "cheapest" model that can do OSPF & Static Routing.
Martin L
I think Cisco sell page recommends any c9000 series switches as a replacement for 3750s.  You just have to pick one that meet you demands.
Regards, ML
**Please Rate All Helpful Responses **
