cpu readings
suthomas1
Level 6
Level 6
I have attached a truncated output from process history command..
Queries-
a) The most recent reading on left side is the first row or second row
b)If we look at right corner, the time goes to 65-70( minutes i believe). How is it that it goes beyond 60 mins.What does that signify?
Please advise.Thanks.
Giuseppe Larosa
Hello Sunny,
a) leftmost column should be time 0 = now
b) simply means the software routine that plots the graph draws more then 60 columns there are no plotted samples above minute 60.
There is a third graph with last 72 hours at the end of the show
Hope to help
Giuseppe
Giuseppe Larosa
Hello Sunny,
Hope to help
Giuseppe
