crypto isakmp not working after IOS upgrade
nova505llc
My vpn router has been running for a very long time using ios version 12.0 (c2600-is56i-mz.120-28a.bin) however I recently upgraded the ios to 12.3 (c2600-i-mz.123-9.bin) but after doing so the crypto isakmp configuration no longer works, during boot I get a cisco invalid input detected at '^' marker for all lines that have to do with the following configuration:
crypto isakmp policy 1
authentication pre-share
crypto isakmp key bl6bOAMxxxxxx address xx.xx.xx.xx
crypto isakmp keepalive 10
crypto ipsec transform-set dnc esp-des esp-md5-hmac
crypto map eth10 10 ipsec-isakmp
set peer xx.xx.xx.xx
set transform-set dnc
match address 150
So the router will boot and remove the above from the running configuration.  Any ideas how to fix? Any help is much appreciated
Leo Laohoo
The IOS loaded doesn't support crypto feature.
Look at the filename of the IOS. It doesn't have the "k9" designation which stands for "crypto".
7 Replies 7
Leo Laohoo
Thank you for you help.
One other question, when I try to load another IOS with k9 I get not enough space error.  Show run shows 48mb:
cisco 2610 (MPC860) processor (revision 0x202) with 41984K/7168K bytes of memory
Flash directory shows:
7864316 bytes total (7864316 bytes free)
The IOS file is 14mb
There should be enough space to load but it won't.
Post the complete output to the following commands:
1. dir; and
2. sh version
dir:
Directory of flash:/
1 -rw- 5485880 <no date> c2600-is56i-mz.120-28a.bin
2 -rw- 2210 <no date> config
8388608 bytes total (2900388 bytes free)
sh ver:
IOS (tm) C2600 Software (C2600-IS56I-M), Version 12.0(28a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 21-Apr-04 21:42 by cmong
Image text-base: 0x80008088, data-base: 0x809BD8B4
ROM: System Bootstrap, Version 11.3(2)XA3, PLATFORM SPECIFIC RELEASE SOFTWARE (fc1)
uptime is 1 hour, 23 minutes
System restarted by reload
System image file is "flash:c2600-is56i-mz.120-28a.bin"
cisco 2610 (MPC860) processor (revision 0x202) with 41984K/7168K bytes of memory.
Processor board ID JAB025305AW (3056935962)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
5 Ethernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Make sense.
The router flash size is only 8 Mb and the IOS file is 14 Mb.
Isn't the total size the 41984K/7168 though?
That is DRAM.
