CSCth46154 - Tracebacks when configuring QoS in 15.1.2T & 15.1.2T0a & 15.1.3T
wleppens82
Abstract    : Tracebacks when configuring QoS in 15.1.2T & 15.1.2T0a & 15.1.3T
Description : When configuring QOS we are having tracebacks in our logging. I need to know when it will be fixed and if the bug is service impacting? - The bug is not visible on CCO.
Bug CSCth46154:%SYS-2-INTSCHED 'may_suspend' after attach service policy in ATM sub-int The associated bug is NOT fixed in 15.1.3T - I still see the tracebacks when configuring QoS polices on the ATM/DSL line :
C887-3G#
Jan 13 09:06:24.010: %SYS-2-INTSCHED: 'may_suspend' at level 4  -Process= "Exec", ipl= 4, pid= 124 -Traceback= 0x804D379Cz 0x8220C030z 0x81B13448z 0x81AFE450z 0x81C42694z 0x81B7151Cz 0x81B6BFF8z 0x81B6C310z 0x81B6D8F8z 0x81C8E080z 0x80D48FB4z 0x800A1B40z 0x800A1BE0z 0x800A04BCz 0x8096FA20z 0x80904050z Jan 13 09:06:24.014: %SYS-2-INTSCHED: 'may_suspend' at l
bmathesw
This bug is internal and that's the reason you are not able to see it on CCO. It should be fixed in 15.1(4)T which is due in early April.
Maybe worth a TAC case, to get some attention of the Development Engineer who fixed it since there is not much information available internally as well in terms of service impact. There are engineering special re-build images available as well if you want to get one and test it.
Cheers,
Bhadri - TAC
bmathesw
Cheers,
Bhadri - TAC
