CTRL+SHIFT+6 X on Mac OS X
lkc
Hi all,
Possibly an embarassingly simple question.
But do anyone know how to break a reverse telnet session from Mac OS X ??
Normally on windows we would use "CTRL+SHIFT+6 X" but the same approach does not work for mac ?
Any hints ?
Lasse,
bstremp
Level 2
Level 2
Use the command "disconnect line " to disconnect the reverse telnet session.
antonhultberg
I know this is a very old thread. But we had problem stopping commands when we switch to Mac OS as well.
CTRL + SHIFT + 6 would not work and I couldn't find any other solution.
Found out you can simply press CTRL + 6, so leave out the SHIFT-key.
..i tried CTRL+SHIFT+6 and even CTRL+6 on my mac (Sequoia 15.1.1 M1 pro) and doesn't work; Where am I going wrong?
RB
