DAI Configuration in Multi-Layer Switching Environment
rmujeeb81
Hi All,
I would like to know if we need to enable ip dhcp snooping and ip arp inspection on the core switch as well ? The switching design is a collapsed core with multiple access switches and there is a Microsoft DHCP server reachable through routing. Core switch is having SVIs for all user vlans and configured with ip helper-address command.
So kindly guide if we need to enable ip dhcp snooping and ip arp inspection globally on the core switch as well ( along with access switches ) for end user vlans ?
ip dhcp snooping trust and ip arp inspection trust is already configured on the trunk between access switches and core switch (both sides).
Philip D'Ath
I guess if only trusted devices plug into the core and no users - no you don't.
