Data Input and Output rate
Jasa2022
Hi there,
I have a Cisco 890 router which is connected on port Fast Ethernet 7 to our main distribution core switch on Gigabit 0/17. Please see the interface F7 results and provide me with your reviews. I think this is a bottleneck and requires an upgrade.
Cisco890#sh int f7
FastEthernet7 is up, line protocol is up
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 205/255, rxload 208/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
Last input 00:00:01, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 81713000 bits/sec, 10328 packets/sec
5 minute output rate 80451000 bits/sec, 10196 packets/sec
2204818416 packets input, 2370650030 bytes, 0 no buffer
Received 404390141 broadcasts (236357208 multicasts)
0 watchdog, 0 multicast, 0 pause input
1573064687 packets output, 132128140 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
753419 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Waiting to hear your feedback.
Joseph W. Doherty
Why do you think this interface is a bottleneck?
Since your 890's interface F7 is "only" 100 Mbps, and many LAN host NICs can do 100 Mbps or better, a 100 Mbps inteface in a transit path, now a days, could be, and possibly is, a bottleneck.
Yet, in your stats, although this interface is showing about a 80% usage, both in and out, for a five minute average, it's also showing no drops.(?)  The latter is a surprise.  Since there are no drops (ignoring the unknown protocol drops - which shouldn't be an issue), interface is not running at 100%, it doesn't really appear to be a bottleneck.  That said, there might be other bottleneck(s) upstream of this router interface.  If so, and in fact if this router's interface isn't the bottleneck, upgrading it will make no difference.
5 Replies 5
I do not see any packet or output drops. What are you running into exactly ? The link is fairly loaded. The only real option is to get a router with a GigabitEthernet interface, obviously.
Jitendra Kumar
I can see unknown protocol drops
that is the reason:-DTP which is enabled by default on the switch interfaces and the router doesn't understand DTP.
Jitendra
Joseph W. Doherty
Hi Joseph,
I really appreciate your review and response. It helped me understand more about the interface information.
BTW, if your using the Ethernet ports on the 890 for LAN switching, and your hosts are directly connected to it, running their Ethernet interfaces at 100 Mbps, if they have gig capable NICs, then upgrading to a small gig standalone switch may very much improve transfer rate between hosts connected to it.
Also, if your hosts are all connected at 100 Mbps, 80% constant usage average would be in the ballpark for a host sending as quickly as it can to another, but unless you have more than one host sending to another host (all with ports of the same speed), you won't see drops in the router as the sending host cannot, physically, overrun the egress router interface.
In other words, the router isn't a bottleneck in the sense itself is not being adverse to data transfer rate between hosts.
Picture two hosts with a single 100 Mbps link between them.  Insert a switch or router into that link, still using 100 Mbps, the switch or router, itself, doesn't cause any additional bottleneck beyond what the link alone provided.  Yet, if you want to go "faster" than 100 Mbps, you would need "faster" host NICs and possibly "better" Ethernet cable (and if there was a switch or router in-line, when you upgrade the link wires to gig, it would be a bottleneck, itself, if it too can not support that rate).  If the somewhat subtle distinction isn't clear, please let me know.  But again, think of a wire without any switch or router in-line vs. one in-line, and then consider, is the in-line switch or router creating a bottleneck not already there from the wire alone.
