default setting for "logging rate-limit" command
cisco24x7
Level 6
Level 6
I have brand new VXR7206 router. I put in
the following command:
logging on
no logging rate-limit
Now I want to restore the "logging rate-limit" back to the router original
default setting. What is the correct command? In other words, when I perform
"show run | inc logging", I do NOT want
to see any "rate-limit" in the config.
How can go about achieving this?
Thanks.
ferikci
Try default logging rate-limit command. Hope this helps.
No logging is the correct way to disable it
If you didnt save it reload it it will probly remove it from run config
, if its not production yet
From the Docs
Setting a Logging Rate Limit
You can set a limit on the number of messages that the access point logs per second. You can enable the limit for all messages or for messages sent to the console, and you can specify that messages of a specific severity are exempt from the limit.
To enable a logging rate limit, follow these steps, beginning in privileged EXEC mode:
Command
Purpose
Step 1
configure terminal
Enters global configuration mode.
Step 2
logging rate-limit seconds
[all | console]
[except severity]
Enables a logging rate limit in seconds.
•(Optional) Apply the limit to all logging or only to messages logged to the console.
•(Optional) Exempt a specific severity from the limit.
Step 3
end
Returns to privileged EXEC mode.
To disable the rate limit, use the no logging rate-limit command in global configuration mode.
I just tested this on an ASR and ISR same as your router
config)#do sh run | i logg
logging discriminator ACL15X msg-body drops fman_fp_image: list 15
logging buffered 100000
no logging console
EDIT: no just rate limit seems all logging commands the same , i removed it all just to check
no logging buffered
no logging console
no logging monitor
Mark Malone
Found it ......
This will remove it from CLI
logging rate-limit console 10 except errors
here it is working
xxxxxxxxx(config)#logging rate-limit 1000
xxxxxxxxx(config)#do sh run | i logg
no logging console
no logging monitor
logging enable
ip ssh logging events
logging source-interface Loopback3
logging host x.x.x.x vrf Mgmt-vrf
xxxxx(config)#logging rate-limit console 10 except errors
no logging console
no logging monitor
logging enable
