delete /force /recursive flash:/
NetAdmin17
I accidentally deleted the whole flash in this command instead of adding an image name at the end.
 I’m now able to boot from usb but copying the image to the flash: is not working.
- is there anyway I can recover the flash that was deleted?
- if not, how can I copy to the flash from usb?
7 Replies 7
Leo Laohoo
What is the model of the switch?
2960x
Download the TAR file into the USB flash and use the following command to put the IOS back into the switch:  archive download-sw usbflash0:filename.tar
archive command is not available in switch:
If the BIN file is in the USB flash, then use the ROMMON command:  boot usbflash0:IOS_filename.bin
Joseph W. Doherty
Copy .bin to flash should work.  Did you update/check bootvar?
That aside, what @Leo Laohoo suggests should set everything correctly for booting.
