Deleting a directory in flash
jigsaw2026
I'm preparing to upgrade the IOS on my c3750, but first I need to delete an old image out of flash. This was originally downloaded as a .tar file, and as such is now in a directory format rather than just the .bin.
Is there a quick way to delete the whole directory? I can only find info on deleting files, and it's going to take me a very long time to delete each file in turn!
I'm sure there's a really simple answer to this!
J
stephen.stack
Level 4
Level 4
This gets rid of a directory and everything in it.
delete /force /recursive flash:
HTH, Pls rate if it does.
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
stephen.stack
Level 4
Level 4
Stephen
It worked perfectly :)
J
