Dhcp ip helper question
mahesh18
Level 6
Level 6
                   Hi everyone,
We have two remote sites and they are connected via ospf.
Site 1 has Router 1 and site 2 has router 2.
Router 1  which has dhcp config on router for data and Voice pool.
ip dhcp pool data Site 1
network 10.74.150.0 255.255.255.128
default-router 10.70.150.1
ip dhcp pool data Site 2
network 10.74.151.0 255.255.255.128
default-router 10.70.151.1
Voice  DHCP pool site 1
ip dhcp pool Voice  Site 1
network 10.74.52.0 255.255.255.128
default-router 10.74.52.1
ip dhcp pool Voice  site 1
network 10.74.52.128 255.255.255.128
Voice DHCP  pool Site 2
ip dhcp pool voice site 2
network 10.74.53.0 255.255.255.128
default-router 10.74.53.1
network 10.74.53.128 255.255.255.128
defailt-router 10.74.53.1
data has vlan 2 and voice has vlan 3.
My question is ip helper address command  on router 2 which is at site 2
1>what ip address should i use on ip helper
option 1 r1 ospf  ip address ?
2>where should i apply ip helper address command on vlan 2  and vlan 3 or under R2 ospf interface
thanks
mahesh
Mahesh
I think that these are the correct behaviors. I said the helper-address should be on the interface where the client request is received and the client request comes in to the vlan interface and not in to the wan interface. And the helper-address should be the address of the router where the DHCP is configured, so the OSPF neighbor address would be the correct address. So your configurations are the correct way to go forward.
Rick
Rick
Richard Burts
Mahesh
You would configure the ip helper-address command on router 2 on the interface where the client request for DHCP is received. And the address to use in the helper-address command is the address of the server that will offer the DHCP address, so it would be the address of router 1.
Rick
Rick
Hi Rick,
Thanks for reply.
Here is what i found after doing some testing.
On R2 router if i config ip helper address under R2 wan interface it does not work.
But when i config ip helper address under data vlan 2  ip helper works fine.
Also what ip address to use for ip helper  here is testing results
when i use default router ip address under dhcp pool of data it does not work.
When i use the ospf nei ip address of R1 router   then pc connected to R2 is able to get ip address and its gateway is
default router ip under dhcp pool.
Need to confirm if this is correct way to going forward?
MAhesh
Mahesh
Rick
Rick
Hi Rick,
Many thanks again.
MAhesh
