DHCP issue in VLAN
charles037
I have a router on a stick setup i guess
Multi-WAN doing a load balancing in pfSense
5 Vlans setup on one interface and 1 DMZ setup on another interface
Vlan 1 being used for Management w/o DHCP Server
Vlan 24 for intranet Wifi w DHCP Server
Vlan 30 for intranet w/o DHCP Server
Vlan 50 for Public Wifi w DHCP Server
Vlan 100 for Ubiquiti ToughSwitch and APs, w DHCP Server
Now, the Vlan goes to a Cisco SG500X switch in port 1, trunk mode, Vlan 1UP, 24T, 30T, 50T, 100T
port 35, trunk mode, Vlan 1T, 24T, 30T, 50T, 100UP, goes to Ubiquti ToughSwitch
In Ubiquiti ToughSwitch, Vlan 1, 24, 30, 50 all tagged and 100 untagged
ToughSwitch goes to UAPs with Vlan 24, 30, 50
Now, my problem is, I'm not able to ping any of the APs
I'm not able to SSH to any of the APs
It's like being isolated
In my firewall settings, I allowed all traffics but still no luck
Can anyone give me some lights here please?
THANKS!
PLEASE USE THE IP ADDRESSES AS YOU WANT
########## Config on SG-500 ########################
interface vlan 1
 ip address 192.168.5.2 255.255.255.0 (PFsense_FWAL_subnet)
 no ip address dhcp
 ip dhcp relay enable
 bridge multicast forward-all add gi1/1/1,gi1/1/44,gi2/1/36
interface vlan 24
 name "Internal Wifi"
 ip address 192.168.3.1 255.255.255.0 (Wifi)
 bridge multicast forward-all add gi1/1/44,gi2/1/36
interface vlan 30
 name DMZ
 ip address 192.168.4.1 255.255.255.0 (DMZ)
interface vlan 50
 name All
 ip address 192.168.2.10 255.255.255.0 (ALL)
interface vlan 100
 name Management
 ip address 192.168.6.1 255.255.255.0 (For AP)
interface vlan 200
 name vMotion (Vmotion)
 ip address 192.168.7.1 255.255.255.0 (v
interface gigabitethernet1/1/1
switchport mode access
switchport access vlan 1
description (Connect-to-pfsense-FWAL)
interface gigabitethernet1/1/2
switcport mode trunk
switchport trunk allowed vlan add 24,30,100,200
description (Coonect-to-UBI-Switch)
ip routing
ip route 0.0.0.0 0.0.0.0 192.168.5.1 (PF-sense-IP)
############## Config on PFsense ######################
Add routes for all the subnets
192.168.2.0 255.255.255.0 192.168.5.2-->(Switch IP)
192.168.3.0 255.255.255.0 192.168.5.2-->(Switch IP)
192.168.4.0 255.255.255.0 192.168.5.2-->(Switch IP)
192.168.5.0 255.255.255.0 192.168.5.2-->(Switch IP)
192.168.6.0 255.255.255.0 192.168.5.2-->(Switch IP)
192.168.7.0 255.255.255.0 192.168.5.2-->(Switch IP)
############## Config on UBIswitch ####################
interface gigabitethernet x/x/x
description (Coonect-to-cisco-SG500)
int gi x/x
switchport access vlan 100
description (Connect-APS)
int gi x/x
12 Replies 12
vishal vyas
(L3-V100)FW<---trunk(tag-L2-V100)--->cisco<--trunk(tag-L2-V100)-->ubiswi-->access-port-V100 to AP
Please check you config as above
tag v100 and untag v1?
The problem is that my AP needs to have access to Vlan 24, 30, 50 too
Do I need to setup DHCP relay or server in SG500X?
If you are doing L3 routing on FW correctly, then it should work without any problem.
Please do the trace route from your AP
Antonio Knox
Level 7
Level 7
I would say that your problem lies with the SG500x.  If I'm not mistaken, these switches don't support VTP, and I don't know anything about Ubiquiti switches.  The symptom appears to be that you have vlan trunking issues.
Perhaps by chance you were able to get vlans trunked down transparently to the SG500x...  Have you confirmed that the Ubiquiti switch sees these vlans?  I don't know how you'd do that, but this wreaks of an L2 issue.
Please rate if helpful.
Current setup like this
Thank you very much
I'm new to VLAN and Layer 3 Switches
Previously we only have Layer 2 Switches and it runs without any issues
After we change out 2 Layer 2 Switches and replaced with 2 Layer 3 Switches stacked together, I'm no longer able to see those APs from pfSense
Please see attached.
I'm sorry
I don't quite understand
I'm a newbie in VLAN
Can you be more specific please?
Thank you very much
I am presuming that you have created all L3 vlans on pfsense firewall, and if that is the case, then Please follow this link:
https://www.highlnk.com/2014/06/configuring-vlans-on-pfsense/
Please check the VLAN and FIREWALL settings.
If you can send some snapshot from your pfsense firewall it would be great to find the issue.
I've also attached the SG500X config file
I know I may have did something wrong in it too
interface vlan 1
 no ip address dhcp
interface vlan 24
interface vlan 30
 name DMZ
interface vlan 50
 name All
interface vlan 100
 name Management
interface vlan 200
ip routing
int gi x/x
int gi x/x
Thanks vishalvyas
Got it working now
