DHCP issue on 1811w does not provide IP to connected Laptop
mahesh18
Level 6
Level 6
Hi Everyone,
I am setting up 1811w router for accessing internet.
DHCP is configured on it but it is not providing IP to laptop connected on port fa6.
Here is config of router
dot11 ssid internet
vlan 98
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 010907150A59111C390C
ip source-route
ip dhcp pool WIRELESS
   import all
   network 192.168.98.0 255.255.255.0
   default-router 192.168.98.1
   dns-server 4.2.2.2
   lease 3
ip cef
no ipv6 cef
vtp mode transparent
archive
log config
  hidekeys
vlan 98
bridge irb
interface Dot11Radio0
no ip address
encryption vlan 98 mode ciphers tkip
ssid internet
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
no cdp enable
interface Dot11Radio0.1
interface Dot11Radio0.98
encapsulation dot1Q 98
no cdp enable
bridge-group 98
bridge-group 98 subscriber-loop-control
bridge-group 98 spanning-disabled
bridge-group 98 block-unknown-source
no bridge-group 98 source-learning
no bridge-group 98 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface FastEthernet0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
switchport access vlan 98
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
shutdown
interface Vlan98
no ip address
interface Async1
no ip address
encapsulation slip
interface BVI98
ip address 192.168.98.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 98 protocol ieee
bridge 98 route ip
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login
end
thanks
mahesh
2 Accepted Solutions
Mahesh
Please try this in addition to my previous suggestion.
Interface VLAN 98
Bridge-group 98 spanning-disabled
Rick
Rick
Mahesh
This command disables spanning tree from running on the interface. Here is a link to a command reference which explains a bit more about it.
http://www.cisco.com/en/US/docs/ios/bridging/command/reference/br_a1.html#wp1015030
The logic that I used was this:
- the wired ports are in a vlan.
- for PCs connected to ports in the wired vlan to get addresses from DHCP there must be an IP address on the vlan or the vlan must be related to IRB and the BVI.
- you demonstrated that putting an IP address on the vlan will allow DHCP to work. But it requires that there be a separate DHCP pool. And you wanted to use the same pool for wired and wireless.
- So the wired vlan needed to relate to IRB and the BVI.
- the way to relate the vlan to IRB and the BVI is with the bridge-group command.
- But when you applied the bridge-group 98 command to the vlan then the vlan went to protocol down.,
- So I assumed that there should be some other command related to bridge-group that would allow the vlan to stay up. So I looked for other bridge-group commands.
Rick
Rick
22 Replies 22
Richard Burts
Mahesh
It appears to me that the problem is that your DHCP pool is associated with the BVI. Interface fa6 is part of VLAN 98. But there is nothing to associate or connect VLAN 98 with the BVI.
Rick
Rick
Mahesh
In re-reading my response I realize that I tried to identify the problem but did not suggest a solution. So let me suggest this
Interface VLAN 98
Bridge-group 98
Give it a try and let us know if it works.
Rick
Rick
Hi Rick,
I did as you said.
but after doing this int vlan 98 status has changed from up up to up down.
still dhcp not working.
thanks
Mahesh
Hi Rick,
One thing to add is that without int vlan 98
bridge-group 98 command wi fi laptops are able to get the IP from dhcp but wired pc does not.
thanks
mahesh
Mahesh
I wonder if the problem has to do with the encapsulation command on the radio. Would you try it and see if this version of the command is supported
encapsulation dot1Q 98 native
Also it might be helpful if you would post the output of show ip interface brief.
Rick
Rick
Hi Rick & Reza,
Here is what i did
On the encapsulation command i added native it supports it.
Also i found that DHCP was working for Wirless connections with out command-  bridged group 98 under vlan 98
ip int vlan 98
bridged-group 98
But  DHCP was still  not working for wired PCs.
So this is what i did
added new dhcp pool
ip dhcp pool vlan1
   import all
   network 192.168.97.0 255.255.255.0
   default-router 192.168.97.1
   dns-server 64.59.144.19
   lease 0 0 1
interface Vlan1
description Wired connections
ip address 192.168.97.1 255.255.255.0
After adding above config DHCP is working fine for wired PCs as shows below
1811w#                          sh ip dhcp  binding
Bindings from all pools not associated with VRF:
IP address          Client-ID/              Lease expiration        Type
                    Hardware address/
                    User name
192.168.97.6        01f0.bf97.de4f.48       Oct 21 2012 08:32 PM    Automatic
192.168.98.2        40fc.894e.c48c          Oct 24 2012 06:23 PM    Automatic
192.168.98.3        a00b.bacf.37a5          Oct 24 2012 06:21 PM    Automatic
1811w#
here is info as per Rick
1811w#             sh ip int brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
Async1                     unassigned      YES NVRAM  down                  down
BVI98                      192.168.98.1    YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
Dot11Radio0.1              unassigned      YES unset  up                    up
Dot11Radio0.98             unassigned      YES unset  up                    up
Dot11Radio1                unassigned      YES NVRAM  administratively down down
FastEthernet0              192.168.99.1    YES NVRAM  up                    up
FastEthernet1              unassigned      YES NVRAM  administratively down down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4              unassigned      YES unset  up                    down
FastEthernet5              unassigned      YES unset  up                    down
FastEthernet6              unassigned      YES unset  up                    up
FastEthernet7              unassigned      YES unset  up                    down
FastEthernet8              unassigned      YES unset  up                    down
FastEthernet9              unassigned      YES unset  up                    down
NVI0                       192.168.98.1    YES unset  up                    up
Vlan1                      192.168.97.1    YES manual up                    up
Vlan98                     unassigned      YES NVRAM  up                    dow
n
Interfaces 2  to 9 are under vlan 1 now.
fa6 is connected to wired PC unde rvlan 1.
Need to why we have interface NVI0 even though NAT is done by some other router.??????
Also need to confirm thay vlan 98 is up down is this ok as we have no port which is in vlan 98 that is up up right now??
Many thanks
MAhesh
Hi Mahesh,
Not very sure about this, but don't you have to also add port 6 to the bridge group?
something like this?
bridge-group 98
Reza
Reza
I would think that the bridge-group would go on the layer 3 interface (interface vlan x) and not on the layer 2 interface (which is already inherently switching/bridging).
I would think that the additional information given by Mahesh sounds like the switch interfaces built into the router were in vlan 1 and not in vlan 98 as his original post suggests. If Mahesh would post the output of show interface status it might give us some insight into what is going on with vlan assignments.
Rick
Rick
Hi  Rick,
Here is info i provided in earlier post.
Seems you did not read it ----
Hi Rick & Reza,
Here is what i did
ip int vlan 98
bridged-group 98
added new dhcp pool
ip dhcp pool vlan1
   import all
   lease 0 0 1
interface Vlan1
                    Hardware address/
                    User name
1811w#
ocol
n
1811w#sh int status
Port    Name               Status       Vlan       Duplex Speed Type
Fa2                        notconnect   1            auto    auto 10/100BaseTX
Fa3                        notconnect   1            auto    auto 10/100BaseTX
Fa4                        notconnect   1            auto    auto 10/100BaseTX
Fa5                        notconnect   1            auto    auto 10/100BaseTX
Fa6                        connected    1          a-full   a-100 10/100BaseTX
Fa7                        notconnect   1            auto    auto 10/100BaseTX
Fa8                        notconnect   1            auto    auto 10/100BaseTX
Fa9                        notconnect   1            auto    auto 10/100BaseTX
Many thanks
MAhesh
Mahesh
In fact I did read the information in your previous post. But thanks for posting it again to be sure that it was part of the conversation.
The show interface status clearly shows that all the router built in switch ports are in vlan 1. And that explains several parts of the problem.
- vlan 98 status is up/down because there are no ports active in the vlan.
- your original post showed that fa6 was assigned to vlan 98 but somewhere along the line that configuration was changed and you did not tell us about that.
- wired ports are not learning DHCP because DHCP is for the network in vlan 98 but there are no ports in vlan 98.
- your new DHCP pool is working because it is providing addresses in vlan 1 and all the router built in switch ports are in vlan 1.
Now that we have a better understanding of the issue - do you want to leave things as they are (and are working I guess) or do you want to go back to the original configuraton where fa8 was in vlan 98?
Rick
Rick
Hi Rick,
Thanks for reply
Earlier the port fa6 was in assigned to vlan 98 and it had wired connection to PC.
Then i config new DHCP pool vlan1 and assigned all ports to vlan 1
after this PC connected  to port fa6 got IP from DHCP  pool vlan1.
Note Fa6 was wired conenction and it got IP from Vlan1.
Now question is if we assign fa6 back to vlan 98 will it get the IP from DHCP.
I tested and assigned port fa6 back to vlan 98 and it did not get the IP
here is info
ocol
Vlan1                      192.168.97.1    YES manual up                    down
Vlan98                     unassigned      YES NVRAM  up                    up
So my only question remains is port fa6 when assigned to vlan 98 and has wired connection should get IP from DHCP
or not?
If yes is there any reason why it is not getting IP from DHCP?
Mahesh
Mahesh
It should be possible for hosts connected to the wired ports to get addresses from the DHCP that supplies the wireless also. This would require that the wired ports and the wireless are in the same VLAN and both participate fully in IRB. If it is not working then there is probably some issue in the configuration. Please post the current configuration so that we can try to find the issue.
Rick
[edit] it would also be helpful if you post the output of show interface status
Rick
Hi Rick,
Good Morning !
Here is current config
1811w#sh running-config
Building configuration...
Current configuration : 3162 bytes
! Last configuration change at 22:37:51 MST Sun Oct 21 2012
! NVRAM config last updated at 15:15:11 MST Sun Oct 21 2012
version 12.4
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
hostname 1811w
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 4096 informational
no logging console
no aaa new-model
clock timezone MST -7
clock summer-time MST recurring
dot11 syslog
dot11 ssid ACDinternet
vlan 98
authentication open
guest-mode
wpa-psk ascii 0 zaq12wsx
ip source-route
ip dhcp excluded-address 192.168.98.1
ip dhcp excluded-address 192.168.99.1
ip dhcp excluded-address 192.168.99.2
   import all
   lease 3
ip dhcp pool vlan1
   import all
   lease 0 0 1
ip cef
no ipv6 cef
archive
log config
  hidekeys
vlan 98
bridge irb
no ip address
ssid ACDinternet
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
bridge-group 98
no ip address
shutdown
station-role root
description OSPF Connection to 3550A
ip address 192.168.99.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
interface Vlan98
no ip address
interface Async1
no ip address
encapsulation slip
interface BVI98
router ospf 1
log-adjacency-changes
network 192.168.97.0 0.0.0.255 area 0
network 192.168.98.0 0.0.0.255 area 0
network 192.168.99.0 0.0.0.255 area 0
no ip http server
control-plane
bridge 98 route ip
line con 0
line 1
modem InOut
stopbits 1
speed 115200
line aux 0
line vty 0 4
login local
line vty 5 15
login local
ntp logging
ntp server 192.168.99.2
end
1811w#      sh int status
Fa6                        connected    98         a-full   a-100 10/100BaseTX
Thanks for help me on this issue.
Mahesh
Mahesh
Please try this
interface Vlan98
bridge-group 98
Rick
Rick
