DHCP not releasing IP Address + Cisco IOS
vinu4u4ever
Hello, there.
I created a DHCP pool in our Cisco router 887 but unfortunately it is not releasing the IPs.
I'm new to Cisco so please ignore if it is a silly query.
Attached is the configuration taken from the Router.
17 Replies 17
Mark Malone
Your configs ok , have you tried rebooting the router incase the service is locked or its some odd bug ?
try clear ip dhcp bindings * then reload and see if the issue still persists
Hello, Mark.
Thank you for prompt reply.
I tried reloading our router but no luck..
Had a check on DHCP binding,,, nothing is listed but still I ran the clear command unfortunately the issue still presists.
Thanks for helping.
Just so we know what your seeing how are you telling its not releasing the address ?
When you check the show ip dhcp pool does it give out the addresses one by one after each other
Is there anything strange in the logs for DHCP , what version of software are you on
Hello, Mark.
Here is the result:
patchi01#show ip dhcp bind
patchi01#show ip dhcp binding
Bindings from all pools not associated with VRF:
IP address Client-ID/ Lease expiration Type
Hardware address/
User name
patchi01#show ip dhcp po
patchi01#show ip dhcp pool
Pool LAN :
Utilization mark (high/low) : 100 / 0
Subnet size (first/next) : 0 / 0
Total addresses : 254
Leased addresses : 0
Pending event : none
1 subnet is currently in the pool :
Current index IP address range Leased addresses
192.168.1.1 192.168.1.1 - 192.168.1.254 0
patchi01#
Ok so that shows no addresses been given out in the pool , is the problem you cant get an address from the pool on the router or you get the address and then it wont release it ?
You could try command debug dhcp detail and see whats happening on the router when the client is trying to obtain an address or in case its a software bug try a newer version ios from the Cisco website , make sure ip dhcp service is enabled in global config , you can see what services are on by default with sh run all
Hello, Mark.
I'm sorry for the delay in response.
The thing is I'm not getting any ip address in the client PC.
2 details:
What is output from commands
sh interface status
sh ip int brief
Having MSS = MTU size obviously is not good (also is unrelated to your issue, but should be corrected).
MSS = MTU - 40
interface Vlan2
 ip mtu 1412
 ip tcp adjust-mss 1412
Hello, Predrag.
Here are the result as per your request.
Thank you for your suggestion regarding MSS & MTU.
I'll update it acoordingly.
IF you don't mind, can u explain me regarding this MSS & MTU?
Try 'no service dhcp' then use 'service dhcp' to reenable dhcp and see if that helps.
Good luck!
-Austin
Hello, Austin.
Thank you for the resply. Tried your solution but unfortunately the result was same.
At this point. It has to be a bug (maybe related to CSCeb36127 and CSCuh95199) won't say for sure without checking the logs and getting debug dhcp detail result. I would recommend to upgrade the code and this has to fix it.
Your current version is
c880data-universalk9-mz.151-4.M.bin25-MAR-2011
Recommended two are available:
c800-universalk9-mz.SPA.154-3.M8.bin
  31-JUL-2017
c800-universalk9-mz.SPA.153-3.M10.bin31-JUL-2017
I hope this helps. Good luck!
-Austin
