Dhcp Problem
We have a problem with two switches 2960  and router 2901. we have a trunk between switch and router. In router we have a subinterface g0/1.80 for voip and g0/1.90 for data. we show the config of interface and dhcp server router.
Dhcp works ok  for interface f0/3 only for data. When we conected phone never is assigned ip of range 10.161.80.0. and assgned 10.161.90.0. Awesome we could doing call becouse we can connect to default pbx of philips.
When only config at interface with vlan 80 like f0/2, never assigned ip.
Whe did debug  in router and we think the problem is in redline below.
At switch we can´t any config of dhcp.
I try to red this document before to go to bed . Its is posible that I can find the solution but   Anyone can help me please???
http://www.cisco.com/en/US/docs/ios-xml/ios/ipaddr_dhcp/configuration/15-1mt/dhcp-15-1mt-book.pdf
Regards.
config Router 2901
_______________________________
ip dhcp pool datos-pool
network 10.161.90.0 255.255.254.0
dns-server 10.161.1.20 10.161.1.22
default-router 10.161.90.2
ip dhcp pool voz-pool
network 10.161.80.0 255.255.254.0
option 66 ascii tftp://10.161.17.11   >>>>>>>><<this option is for philips phone.
default-router 10.161.80.2
____________________________-
config switch
interface FastEthernet0/1>>>>>>>>>>>>>>>>>>>>>>>>><trunk to router
description enlace contra SWAdmin_2
switchport mode trunk
interface FastEthernet0/2
switchport voice vlan 80>>>>>>>>>>>>>>><vlan voip
spanning-tree portfast
interface FastEthernet0/3
switchport access vlan 90>>>>>>>>>>>>>>><vlan data
ul 17 20:26:55.938: DHCPD: checking for expired leases.
Jul 17 20:28:29.690: DHCPD: client's VPN is .
Jul 17 20:28:29.690: DHCPD: No option 125
Jul 17 20:28:29.690: DHCPD: Sending notification of DISCOVER:
Jul 17 20:28:29.690:   DHCPD: htype 1 chaddr 0060.b957.1f3d
Jul 17 20:28:29.690:   DHCPD: remote id 020a00000aa15a020100005a
Jul 17 20:28:29.690:   DHCPD: circuit id 00000000
Jul 17 20:28:29.690: DHCPD: DHCPDISCOVER received from client 0100.60b9.571f.3d on interface GigabitEthernet0/1.90.
Jul 17 20:28:29.690: DHCPD: Seeing if there is an internally specified pool class:
Jul 17 20:28:29.690: DHCPD: Found previous server binding
Jul 17 20:28:29.690: DHCPD: Sending DHCPOFFER to client 0100.60b9.571f.3d (10.161.90.78).
Jul 17 20:28:29.690: DHCPD: no option 125
Jul 17 20:28:29.690: DHCPD: ARP entry exists (10.161.90.78, 0060.b957.1f3d).
Jul 17 20:28:29.690: DHCPD: unicasting BOOTREPLY to client 0060.b957.1f3d (10.161.90.78).
Jul 17 20:28:29.690: DHCPD: DHCPREQUEST received from client 0100.60b9.571f.3d.
Jul 17 20:28:29.690: DHCPD: Sending notification of ASSIGNMENT:
Jul 17 20:28:29.690:  DHCPD: address 10.161.90.78 mask 255.255.254.0
Jul 17 20:28:29.690:   DHCPD: lease time remaining (secs) = 86400
Jul 17 20:28:29.690: DHCPD: Can't find any hostname to update
Jul 17 20:28:29.690: DHCPD: Sending DHCPACK to client 0100.60b9.571f.3d (10.161.90.78).
Jul 17 20:28:55.938: DHCPD: checking for expired leases.
Jul 17 20:30:55.938: DHCPD: checking for expired leases.
Alexey Minaev
Hi Rafael,
Could you try this config please
Router conf:
option 150 10.161.17.11 - voice server?
default-router 10.161.80.254
description ---  trunk to (2960) ---
no ip address
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/1.80
description --- VoIP (10.161.80.0/24) ---
encapsulation dot1Q 80
ip address 10.161.80.254 255.255.255.0
Switch conf
switchport trunk encapsulation dot1q (on 2960 enabled by default)
switchport trunk allowed vlan 1,80,90
switchport nonegotiate
load-interval 30
switchport mode access
load-interval 30
spanning-tree bpduguard enable
6 Replies 6
acampbell
Hi Rafael,
Your switch config for int f0/2 is the problem
This is your existing config
If this port is only to support a phone please reconfig to be an access port in vlan 80
shut
desc *** PHONE ONLY PORT VLAN 80 ***
no switchport voice vlan 80
switchport access vlan 80
no shut
See if that works
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hi Alex,
thanks for your soon answer. It´s works ok but the problem is that I need vlan data too in this port.
Internet  10.161.80.3             0   0060.b957.1bc3  ARPA   GigabitEthernet0/1.80
You think that the we need to put this command in switch???
SHRRHH_3(config)#ip dhcp-client ?
  broadcast-flag     Set the broadcast flag
  default-router     Set DHCP default router related information
  network-discovery  Configure parameters for network discovery
SHRRHH_3(config)#ip dhcp-se
SHRRHH_3(config)#ip dhcp-server ?
  Hostname or A.B.C.D  IP address or Name of DHCP server
__________________________________-
In other customer, we have this config and works ok.
ip dhcp pool TOIP
   network 10.166.200.0 255.255.248.0
   default-router 10.166.200.1
   option 150 ip 10.166.200.2
   dns-server 10.166.20.35 10.166.20.49
   interface GigabitEthernet1/0/2
switchport access vlan 100
switchport voice vlan 200
switchport port-security maximum 2
srr-queue bandwidth share 1 30 35 5
queue-set 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree guard root
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
Regards.
in this case just redo your intial config but add this:
switchport access vlan x   where vlan x is the data vlan
Regards.
Alain.
Rafael,
The normal config for the kind of port you want would be like this:-
desc *** PHONE AND DATA ***
My question to you is how the phone selects the VOICE vlan.
The VOICE vlan uses 802.1Q vlan taging in the ethernet frames
Cisco AUTOQOS is used for Cisco VOIP (CUCM/CUCME) PBX solutions
Cisco phones use CDP neighbour to find their voice vlan number
Do you enter this manually on the phone config ?
On Nortel/Avaya & Alcatel the Voice VLAN discovery can be part of the DHCP process from the phone.
Phone boot on the DATA vlan, obtain a DATA VLAN ip address.
Other DHCP parameters tell the phone to reset and use 802.1Q tagging to to next find an address on the VOIP Vlan.
I have no experience with Philips IP/PBXs so I dont know their process.
Alex.
Alexey Minaev
Hi Rafael,
Router conf:
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
duplex auto
speed auto
Switch conf
load-interval 30
load-interval 30
Hi Guys
Thanks for your help.We solved the problem like I show you.
For Nec phone we need to appy option 66. This phone don´t work like a cisco phone. Don´t works with cdp.
In switchport of the phone we put Vlan 90 and works!!!!!!!!! only with this change. With command switchport voice vlan x is for cisco phone or Alcatel-Avaya. Nec don´t works with this config.
Dhcp in Router::::::::::::::::::::::::::::::::::::::::::::::.
ip dhcp pool data-pool
ip dhcp pool voip-pool
Config in switch::::::::::::::::::::::::::::::::::::::::::
switchport trunk native vlan 80
switchport trunk allowed vlan 80-90
Internet  10.161.80.3             1   0060.b9  ARPA   GigabitEthernet0/1.80
Internet  10.161.90.6             4   000f.b0  ARPA   GigabitEthernet0/1.90
Thank you very much.
Cheers.
