Dhcp reservation : client-identifier dissapearing
Hi,i want to make a reservation on my dhcp.I`ve done several hundred times but this time the line "client-identifier" just dissapears when the pc is requesting the ip address.
Configuration BEFORE the DHCP REQUEST
ip dhcp pool 76test
   host 192.168.15.76 255.255.255.0
   client-identifier 0100.242c.a12e.b2
    dns-server 192.168.1.240
   default-router 192.168.15.1
Client requests the IP
*Mar  7 18:18:29.427: DHCPD: client's VPN is .
*Mar  7 18:18:29.427: DHCPD: DHCPDISCOVER received from client 0100.242c.a12e.b2 on interface Vlan1.
*Mar  7 18:18:29.431: DHCPD: removing ARP entry (192.168.15.76 vrf default).
*Mar  7 18:18:29.431: DHCPD: Saving workspace (ID=0x7300001D)
*Mar  7 18:18:31.431: DHCPD: Reprocessing saved workspace (ID=0x7300001D)
*Mar  7 18:18:31.431: DHCPD: DHCPDISCOVER received from client 0100.242c.a12e.b2 on interface Vlan1.
*Mar  7 18:18:31.431: DHCPD: Sending DHCPOFFER to client 0100.242c.a12e.b2 (192.168.15.38).
*Mar  7 18:18:31.431: DHCPD: ARP entry exists (192.168.15.38, 0024.2ca1.2eb2).
*Mar  7 18:18:31.431: DHCPD: unicasting BOOTREPLY to client 0024.2ca1.2eb2 (192.168.15.38).
*Mar  7 18:18:31.431: DHCPD: removing ARP entry (192.168.15.38 vrf default).
*Mar  7 18:18:31.435: DHCPD: client's VPN is .
*Mar  7 18:18:31.435: DHCPD: DHCPREQUEST received from client 0100.242c.a12e.b2.
*Mar  7 18:18:31.435: DHCPD: No default domain to append - abort update
*Mar  7 18:18:31.435: DHCPD: Sending DHCPACK to client 0100.242c.a12e.b2 (192.168.15.38).
*Mar  7 18:18:31.435: DHCPD: creating ARP entry (192.168.15.38, 0024.2ca1.2eb2, vrf default).
*Mar  7 18:18:31.435: DHCPD: unicasting BOOTREPLY to client 0024.2ca1.2eb2 (192.168.15.38).
Configuratio AFTER
ip dhcp pool 76test
As you can see the line with " client-identifier 0100.242c.a12e.b2" dissapears.
Any thoughts ?
0 Replies 0
