DHCP segmentation
__Uni-Rider__
Let's say I have the segment 172.25.96.0/24 for a Lan.
I have two routers(1711) in this lan using hsrp and 1 virtual router for the gateway.
How can I separate the segment in my dhcp configuration on both routers in order to have ip resolution when one router is down.
Thank you for your help.
Richard Burts
You have posted the same question in the WAN Routing and Switching forum where I have provided an answer. I suggest that we consolidate the discussion in that forum.
Rick
Rick
