dhcp snooping binding database contents
sarahr202
Level 5
Level 5
<p> Hi every body!<br />
 What are contents of DHCP snooping binding database?<br />
How Can I view this database? could any body give me an example displaying the contents of dhcp snooping binding database?<br />
<br />
Thanks a lot!</p>
Elly Bornstein
It has IP to mac address translation entries based upon DHCP conversations on the vlan.
You can use the command:
ip dhcp snooping database tftp://x.x.x.x/dhcpbinding.txt to store this database somewhere.
It should be readable like a text file. If you store it on flash here is a way to view it, mine has no bindings unfortunately:
Switch-E1#more flash:dhcp.txt
2c2dcbd3
TYPE DHCP-SNOOPING
VERSION 1
BEGIN
END
You can view the bindings with:
show ip dhcp snooping binding
You can also see more specific bindings like:
show ip dhcp snooping binding vlan 100 (show all bindings related to vlan 100)
show ip dhcp snooping binding interface x/y
show ip dhcp snooping binding 10.10.10.10
etc.
