03-07-2017 12:23 AM - edited 03-08-2019 09:38 AM
Could anyone help me to understand what are misdirected packets drops in DHCP snooping statistics ?
C3-2960#sh ip dhcp snooping statistics detail
Packets Processed by DHCP Snooping = 321072
Packets Dropped Because
IDB not known = 0
Queue full = 0
Interface is in errdisabled = 0
Rate limit exceeded = 0
Received on untrusted ports = 0
Nonzero giaddr = 0
Source mac not equal to chaddr = 0
No binding entry = 0
Insertion of opt82 fail = 0
Unknown packet = 0
Interface Down = 0
Unknown output interface = 300
Misdirected Packets = 10878
Packets with Invalid Size = 0
Packets with Invalid Option = 4727
Stephane
03-07-2017 05:36 PM
Hi Stephane
A quick look at Google found this link.
https://supportforums.cisco.com/discussion/10885481/dhcp-snooping-statistics
The key answer is
Misdirected |
Number of packets that was dropped due to having an address that would have caused the packets to be punted. |
http://www.cisco.com/en/US/partner/docs/ios/sbc/command/reference/sbc_01.html
With regards,
03-08-2017 12:08 AM
Yeah I found that too, but Ithat's not very clear for me : do you have an example to illustrate that ?
Thanks & Regards
Stephane
03-09-2017 04:06 PM
Sorry, no real examples, but if you are unsure what punted means there is a heap of documentation on that. Basically it is to do with the cef vs process switching of packets. Any packet that is forced into the processor is a punted packet. If your switch gets its address via DHCP then the count might be for packets that are directed to the switch itself. Or maybe CEF is not running?
