DHCPSNOOP(hlfm_set_if_input)
Joris Deprouw
Hi All,
We have upgraded our 3750 switches from IOS 122-53.SE2 to 122-55.SE8.
Since this update users from several vlans (not all) have issues renewing their ip address.
For all vlans DHCP-snooping is activated.
no ip dhcp snooping information option allow-untrusted
no ip dhcp snooping database
ip dhcp snooping database write-delay 300
ip dhcp snooping database timeout 300
ip dhcp snooping verify mac-address
ip dhcp snooping verify no-relay-agent-address
ip dhcp snooping
000844: Oct 21 12:08:08.948: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Fa1/0/4
000845: Oct 21 12:08:08.956: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Po1 for pak.  Was not set
000846: Oct 21 12:08:08.956: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Po1
000847: Oct 21 12:08:09.543: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa1/0/12 for pak.  Was not set
000848: Oct 21 12:08:09.543: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Fa1/0/12
When we disabled the ip dhcp snooping for the affected vlan, everything works fine.
Cisco tac has already proposed to add command "no ip dhcp relay information check"  related to Option 82 of DHCP.
However after applying this command and reactication ip DHCP snooping. We still have the same issue.
We can see these alerts in the logs:
Did someone see this issue before?
Joris
5 Replies 5
Sandeep Choudhary
Hi joris,
I don't know abt ur topology but still can help little bit.
If on clients already in the binding state then you can do ipconfig/release then ipconfig/renew and see wt happens.
It's all about the path that ur DHCP traffic takes to get to ur access layer switches. All upstream trunk port to the dhcp server need to be trusted(ip dhcp snooping trust)
https://cciereview.wordpress.com/tag/dhcp /
http://blog.ine.com/2009/07/22/understanding-dhcp-option-82/
Check it out these post or put ur topology here.
We see the issue at different sites +20.
Our setup is fairly simple. We have a router on a stick setup. So the switch is pure L2, with a trunk to the router, which has subinterfaces for each vlan. Some sites with 1 router and 1 switch/stack, some with 1 router and multiple switches/stacks.
The uplink ports to the trunk are configured with ip dhcp snooping trust.
Some vlans on that same trunk, managed by the same router don't have an issue. With the old IOS we didn't have any issue. So I doubt that the config is the problem. Maybe new features in the new IOS could cause this problem.
Thanks for you help,
Best Regards,
Joris
I have read the first post
The solution there is to configure the affected ports with command "ip dhcp snoop trust". I ask myself, what's the point of Ip dhcp snooping when you trust every port on the switch.
On the second post
It seems to me the command "no ip dhcp relay information check" is activated on the router.
We only applied it on the L2 switches. Could that be the issue?
Joris
Hi All,
It was a bug in the IOS version.
The problems that we had, was caused by CSCuj03351 bug that was found first on for IOS 12.2(55)SE8 and is in fact a duplicate of CSCui65252
Best Regards,
Joris
Glad that finally you track down the issue.
Dont forget to rate helpful posts
