Discrepencies between IF-MIB::ifTable and IOS "show interface"
ww9rivers
On a WS-C4507R-E switch, I get this on IOS command line:
>show int Te3/2
TenGigabitEthernet3/2 is down, line protocol is down (inactive)
  Full-duplex, 10Gb/s, link type is auto, media type is No X2
However, with a SNMP walk of IF-MIB::ifTable, I get these (copy and pasted):
ifDescr = TenGigabitEthernet3/2
ifAdminStatus = up
ifOperStatus = down
ifConnectorPresent = true
It seems that the results differ. What did I get wrong?
Thanks for help!
j-marenda
> >show int Te3/2
> ifAdminStatus = up
> ifOperStatus = down
This is all o.k.
if you have
int ten 3/2
shutdown
end
then sh int ten 3/2 gives you "ten3/2 is administratively down", and ifAdminStatus = down .
but you have
int ten 3/2
no shutdown
end
so sh int ten 3/2 gives you "ten 3/2 is down" since it is
administratively up (ifAdminStatus = up) BUT the Line-Protocol ist down (ifOPerStatus = down) ,
for example, no cable or neighbor device is off.
Hope this help's,
Jürgen.
j-marenda
> >show int Te3/2
> ifAdminStatus = up
> ifOperStatus = down
This is all o.k.
if you have
int ten 3/2
shutdown
end
but you have
int ten 3/2
no shutdown
end
Hope this help's,
Jürgen.
Thanks, Jürgen,
You have answered my question. But unfortunately, I still have the problem of figuring out how to map what the IOS CLI reports to MIB objects.
As in my example:
The "line protocol is down (inactive)" maps to ifOperStatus nicely.
But what does "TenGigabitEthernet3/2 is down" (not administratively down as you correctly pointed out) maps to? Or is there a MIB object for that at all?
Thanks and regards,
Wei
