Duplicate ping replies from servers using HSRP virtual address as gateway
tmikelson
Receiving duplicate ping replies from servers using HSRP virtual address 10.0.1.224 as gateway.
Servers using specific IP address of one of the Vlan11 interfaces as a gateway DO NOT produce duplicate ping replies.
Pinging the virtual HSRP address of 10.0.1.224 DOES NOT produce duplicate ping replies.
**** Nexus5548-A ****
interface Vlan11
  ip address 10.0.1.223/24
  ip ospf authentication message-digest
  ip ospf message-digest-key 1
  ip ospf priority 225
  ip router ospf 100 area 0.0.0.0
  hsrp 1
    ip 10.0.1.224
**** Nexus5548-B ****
interface Vlan11
  ip address 10.0.1.225/24
  hsrp 1
    preempt
    priority 110
    ip 10.0.1.224
jj27
Do you have peer-gateway configured in the VPC configuration?
There is no VPC configuration, thus no peer-gateway configured.  The Nexus 5548s are two separate switch/routers, not a VPC pair.
Mahadev Patil
At last one interface add to that vlan.
Sent from Cisco Technical Support Android App
Sorry, could you rephrase that please?
