Eigrp summary route question
mahesh18
Level 6
Level 6
Hi all,
If we have Router A connected to 3 different networks and is using EIGRP
172.16.5.144/28
172.16.5.160/28
172.16.5.128/28
so what summary route will be shown in output of sh ip route on Router A
many thanks
mahesh
2 Accepted Solutions
If you want a single summary statement, the best one is this:
172.16.5.128/26
Just make sure there are no overlapping in any other part of the network.
Federico.
Mahesh,
Yes. When you configure eigrp summary address of 172.16.5.128/26, it will have an entry in local RIB pointing to null interface.
Nagendra
5 Replies 5
172.16.5.128/26
Federico.
Nagendra Kumar Nainar
Hi Mahesh,
From your description, all 3 networks are connected to Router A. So it all will be shown as connected route in routing table. There wont be any summary route generated by default.
If you configure a EIGRP summary, an entry pointing to null interface will be installed in your routing table.
HTH,
Nagendra
thanks for reply
so if i config this as summm router then entry in routing table will be
172.16.5.128/26  and it points to null table right?
mahesh
Mahesh,
Nagendra
Thanks for reply
