Embedded Packet Capture Feature on IOS
Gary Lefebvre
Hello, I have (4) 1841 routers and I am using c1841-adventerprisek9-mz.151-4.M7.bin IOS version.
What I would like to do is use the embedded capture feature and what I get at the terminal is:
R4#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R4(config)#monitor ?
  event-trace  Tracing of system events
  session      Configure a SPAN session
Capture is not an option. I need help on how the get the full features to work....
Kind regards...
Hello.
The feature is supported on the platform/release.
You need to exit configuration mode to use it.
Please find details here - https://supportforums.cisco.com/document/139686/configuration-example-embedded-packet-capture-cisco-ios-and-ios-xe
Hello.
Hello Vasilli, thank you for providing me the correct answer! I have one more question. Will embedded packet capture work in Layer 3 switches, Cisco 3550 or 3560?
Hello, Gary.
Sorry, I'm not really familiar with LAN roadmap, so  cannot help you here.
