10-15-2012 10:52 AM - edited 03-07-2019 09:28 AM
Hello Every Body,
I want to know if it is possible to load balance between 2 routes, wich have 2 different ISP interface.
In attachement you have the scenario.
I have my primary router with an ISP of 4 MB
and a second router with an ISP of 2 MB
Is it possible to set the both router to load balance traffic ?
10-15-2012 11:08 AM
It is more like load sharing:
have a look at this link:
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml#conf5
10-15-2012 11:15 AM
is it possible to set this scenario whitout BGP ?
10-15-2012 11:42 AM
yes but only for outgoing traffic with static routes for example. But don't forget this is load-sharing and that it will be performed per-flow( src-dst IP pair).
Regards.
Alain
10-15-2012 12:25 PM
How are the two routers setup HSRP or GLBP or just stand alone?
10-16-2012 12:59 AM
Hello i just want to know what can be the best practice for this goal !.
Mean if i set the 2 routers with GLBP, is it that it will load balance the 2 different ISP?
So if i use for example BGP, i don´t know also, if i´ll enhance or get a kind of load balancing between the 2 routers.
What can be the best recommandation, for this kind of scenario ?
10-17-2012 02:58 PM
If you want to achieve inbound and outbound load balancing you'll need to go with either BGP or a load balancer.
10-15-2012 05:33 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
OER/PfR, if supported by your router platforms, might be ideal for outbound load sharing.
