ENHANCED_LAYER2_PKG
If my Nexus switches, says is missing this:
ENHANCED_LAYER2_PKG           No    -   In use             Grace 83D 3H
This is the license to buy right?
L-N5548-EL2-SAK9=
(My Nexus switches is Nexus55489Up).
Regards Kenneth Dalbjerg
5 Replies 5
Reza Sharifi
Here is the part number for ENHANCED_LAYER2_PKG.
N5596-EL2-SSK9
see table-5 in this link for more info:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/licensing/guide/b_Cisco_NX-OS_Licensing_Guide/b_Cisco_NX-OS_Licensing_Guide_chapter_01.html
Sure?
Is that not for the Nexus N5596?
http://www.cisco.com/c/en/us/support/switches/nexus-5596up-switch/model.html
You are correct. The part number I provided is for 5596 but I am not able to find the part number you posted (L-N5548-EL2-SAK9= )
Can you post a link where you found it?
https://www.amazon.com/Cisco-L-N5548-EL2-PSSK9-Enhanced-Layer-License/dp/B00BRFW6JA
And my local dealer has provide it for me.
He is only a dealer not an cisco experts :).
If other is in the same situration, i can confirm that this is the license to buy:
L-N5548-EL2-SAK9=
If you want to used fabricpath.
