err-disable port with FCS/input errors?
teakay
in view of the occasion i would like to ask if someone knows if there exists any mechanism to automatically shut down a Layer2 fibre port ( which is also member of a LACP-Channel ) with rising FCS-/input errors, such as error-disable at a threshold or something like that?
platform in use is Cat9k with network advantage.
kind regards,
Thorsten
@teakay
 You can use EEM script to monitor and shut the interface if it hits a certain threshold. This blog below is one example but you can find a lot of examples here in the forum also
https://blog.ipspace.net/2011/07/monitor-multiple-interfaces-with-single/
