Error add interface port-channel
Natha340Mai340
Hello everyone, a Customer ask me  to configure a etherchannel between two Switches C3500 XL Version IOS 12.0
follow the first configuration what I done and the output error show me by switch
Sw01(conf)# interface port-channel 1
% invalid input detected at '^'  marker.
so....my question is: I have to do something before add an new port-channel interface ?? why the Sw01 does not accept my configuration ?
any tip is welcome.
I have had a look on the software download page.
The latest and last IOS for these old switches is:-
c3500xl-c3h2s-mz.120-5.WC17.bin
So 12.0.5 is the end.
Here is another old link showing an example of a 3500XL with an etherchannel to a 6500 CATOS
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094689.shtml
I wish you luck with your config.
Should be OK
Alex
Regards, Alex. Please rate useful posts.
acampbell
This is quite old stuff nowadays.
Try this
interface FastEthernet0/1
port group 1
interface FastEthernet0/2
port group 1
This link may help you
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc6/cli/clicmds.html#wp1787023
Alex
Think you acampebell, I'm go to test.
what do you think about I upgrade from version 12.0 to 12.3 or 12.4 ?
my customer sometimes complains of slow. I've checked there is only an cable between two switches....so I want
establish an etherchanel with three ports maybe we earn speed...I think
thanks
Should be OK
Alex
