errors on LAN interface
Sameer Gautam
We are using Cisco Router 1841 and users reporting issue related to VoIP. After investigation, seeing input errors on Router LAN interface, but there is no error on connected switch interface. Any Suggestion what is going wrong on this interface?
Tried to swap interface and cable but no luck. Still problem persist.
736 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
Router config is
ip address xx.xx.xx.xx xx.xx.xx.xx
ip access-group 113 in
ip helper-address xx.xx.xx.xx
ip route-cache flow
load-interval 30
speed 100
full-duplex
vrrp 1 description primary active GRP1
vrrp 1 ip xx.xx.xx.xx
vrrp 1 preempt delay minimum 20
vrrp 1 priority 105
vrrp 1 track 1
vrrp 1 track 2
arp timeout 60
service-policy output PolicyMap_0
hold-queue 200 in
end
interface GigabitEthernet1/0/1
description "Connection to router"
switchport access vlan xx
duplex full
speed 100
jawad-mukhtar
Level 4
Level 4
ON Which Interface us recieving Error
Paste Sh Run of That Interface and Also Neighbour Swhitch Interface Shurn Run
Jawad
johnlloyd_13
Level 9
Level 9
Try setting the port to auto/auto and test again.
