export syslog through vrf interface on cisco 7206 vxr
donnie
Hi all,
I have a cisco 7206vxr with ios 12.4 configured with a vrf interface and would like to know if its possible to export syslog of my router through the vrf interface to my syslog server? If yes, what command should i use? TIA!
Steve Fuller
Level 9
Level 9
I've never used it myself, but once you've created the VRF and associated one or more interfaces with that VRF, you should be able to simply add logging host <syslog-ip> vrf <vrf-name> as a global command.
Steve Fuller
Level 9
Level 9
Hi Steve,
Thk you for your prompt response, i will try on my actual router and let you know if it works. It works for cisco7200 on gns3!
Hi Steve,
Your command works after "logging trap" command is enabled. Thank you.
