Extending same VLAN across multiple distributions
patrick.guerin
Just wondering what the current thoughts are on the following common problem  .......
  • Have 3 x L3 distribution pairs (#1, 2 and 3) with a number of fully redundant L2 access switches off each
  • Distributions are connected via a L2 core
  • VLAN X is root/root secondary on Distribution Pair 1. Need to extend the same VLAN X to L2 access switches hanging off Distribution Pair 2 and 3.
  • Single Mode fiber between distributions. Multimode fiber between access and distribution.
Do I simply connect a fiber from Distribution Pair 1 to both Distribution Pair 2 and 3 and extend down to access via trunk? This is obviously possible but not allowing for a clear demarcation and could cause instability from one network to extend to another.
Do I play it safe and put in a L2 aggregation switch (with fiber ports) beside each of Distributions 2 and 3 and in turn have dedicated (parallel) access switches for that VLAN X. This is a waste but would probably less of a risk than the first option.
Other options?
Patrick
danielmcollins
Patrick,
- do you have VTP running on the network?
- are there any overlapping VLAN's between distribution sites?
- what's the distance between distribution sites? Do you expect high latency?
- what's the diameter of the switched network?
Assuming no VTP, no overlap, small distance/low-latency between sites, relatively small # of hops between hosts that need to talk ...
You can safely connect each of the distribution sites together for VLAN X. You should manually prune all VLAN's except VLAN X on the new distribution trunks. Use "switchport trunk allowed vlan X".
hth,
Dan
Andrew Cink
This is a pretty tough one. There might be some options in Nexus that would let you do it.
Basically, if it's layer 3 between switches, you're pretty screwed.
You COULD go to a hybrid layer 3 model, where you trunk vlans across all of the switches as suggested above, and move the L3 IP configuration from the interface on the switch to a SVI, then trunk that SVI between switches to keep the layer 3 routing working. So basically you could have layer 3 connectivity using the IP addresses on trunked vlan Y, and then add vlans X and Z to the trunk to have the same layer 2 vlan in all 3 areas.
Andy
