Failover in VSS configuration
Elie Sbat
Hi Guys,
due to some reasons, the sup720 hanged and stopped responding and this problem did not trrigger the failover to the second chassis and I went into downtime. I would like to know why the failover did not trigger. I am using the following configuration:
Switch 1:
switch virtual domain 100
switch mode virtual
switch 1 priority 110
switch 1 preempt
mac-address use-virtual
Switch 1
interface TenGigabitEthernet1/5/4
no switchport
no ip address
mls qos trust cos
channel-group 1 mode on
interface TenGigabitEthernet1/5/5
no switchport
no ip address
mls qos trust cos
interface Port-channel1
description ## For VSL ##
no switchport
no ip address
switch virtual link 1
mls qos trust cos
no mls qos channel-consistency
interface GigabitEthernet1/5/3
no switchport
no ip address
dual-active fast-hello
switch mode virtual
switch 1 preempt
Swith 2
interface TenGigabitEthernet2/5/4
no switchport
no ip address
mls qos trust cos
channel-group 2 mode on
interface TenGigabitEthernet2/5/5
no switchport
no ip address
mls qos trust cos
interface Port-channel2
no switchport
no ip address
switch virtual link 2
mls qos trust cos
interface GigabitEthernet2/5/3
no switchport
no ip address
I would like to know if there is any missing command that might trigger the failover in case of sup720 damaged ?
Thank you
rsimoni
show redundancy
and show redundancy history might give the first clues.
PS: the VSS config is not that important for SSO
