Features
join_sn09
Dear All,
i have question to ask you.My quetion is:
How can i know advantage of ios?
Example:
c2960-lanbasek9-mz.122-25.FX.bin
Best Regard
Join
cameron.moody
Hi Join,
You can use the IOS Feature Navigator located at http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
You will however need a CCO login to be able to use this tool. It will then list the features that the particular IOS supports. You can also use it to search for IOS compatible with your particular hardware and memory requirements of each etc.
Hope this helps.
Dear Cameron,
Thank you for show me.
Best Regards,
Join
