Fibre config commands
magyshanks2020
I just Installed GPEC Fibre To the 2 switches
I want to configure it but i forgot the codes..
How to set it as single mode or Doublemode?
anyone can help?
Reza Sharifi
What type of switches? Is the interface up?
Cisco 3xxx yes interface is up and the router default vlan IS defined
...I'm using it on copper cables .. Server switch  is distributing internet  to other Switches using trunks and it's distribution internet already..
I just installed the fiber gbec yesterday
Did i answer ur question?
