Firewall and switch not communicating
Jah8887
Hi all, I am new to the forums and hope I post this in the right area.
I am setting up a small business and cant get their firewall and switch to ping each other. I have the setup below.
Comcast Business(internet) > ASA 5508-x firewall inside port >SG550X 24MP switch (port 24 connected to inside port on firewall)
I have tried just about everything I can think of and to no avail.  What I have found out though is once I plug the inside port from firewall to port 24 on the switch it locks up the switch and I have to reboot it.
Firewall
I have
enabled dhcp with only 2 addresses .1 for firewall and a .2 for switch
and tried with disabling dhcp but set static .1 address on inside port
I have tried modifying ACL lists
Tried Natting
I tried keeping the ports on the same vlan e.g. 1
Factory defaults and trying from scratch
and probably more than I can remember
Switch
I have
Disabled DHCP
Enabled DHCP
Without the cable plugged into port 24 I tried assigning a static IP to this port through the gui and it bombs out everytime.
I used the command line to assign the static IP to the port 24 and it takes but locks up once I plug the cable into it.
I have disabled DNS on the switch
Disabled port security
Enabled port security
Disabled smartport
enabled smartport
disabled all vlans except for .1 and tried to get them to communicate with just one vlan
Tried setting up different vlans with no luck
and more
Any ideas on how I can get these 2 communicating, so that the dhcp server I will be hooking up to the switch, will give out the addresses and dns entries, to the rest of the wired devices on the network and allow the devices to get out to the internet?
I have a feeling I am missing something but not sure what.
Hi @Jah8887
   This should be something really straightforward. Take a look on the file attached. This is from a simple lab I was playing with. This switch is not SG550X but might help. The ASA is 9.X, probably the same you have. This device communicate with no problem on my Lab.
 Take a look, try to understand the config and let me know if you need help.
I don't have DHCP on switch, as you can see, but, this is not complicate. Some configs on this file may be disregard by you as you may do not need it.
Just make both device communicate and then we can go one step further.
-If I helped you somehow, please, rate it as useful.-
