flash and bootflash difference
heavenix_1982
Community Member
hi all,
what is difference between flash and bootflash ? is bootflash a compact flash card too?
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
On what device?  7200?
Bootflash generally hosts a bootloader program.  Depending on device, it might be a very small basic bootloader, i.e. just enough to perhaps do some quick hardware startup diagnostics and then boots the main IOS.  Or, bootlflash might contain a "miniature" IOS.  Flash generally hosts the main IOS program.
When there's a bootflash, it's sometimes the destination of crash files.
Some Cisco devices have a bootrom that is erasable.  While a bootflash can often be worked with using typical flash commands (e.g. dir, format, copy, del) and has a directory structure, flashable bootrom normally requires a special command to update it and doesn't have a directory structure.
Bootflash, like most earlier flash memory, is normally provided by internal flash memory.
