Frame errors on 7513 fastethernet adapter
ddvmsk2005
I have Cisco 7513 with fastethernet adapter PA-FE-TX connected to Catalyst WS-C2948. And i have permanent frame (and some time input) errors. Errors rate is block of about 22-30 errors each 10 seconds. I have disabled KeepAlive on router but C2948 don't have this option. I try to change cables but nothing change. How i can find problem?
Catalyst version:
WS-C2948 Software, Version NmpSW: 6.4(17)
Copyright (c) 1995-2005 by Cisco Systems, Inc.
NMP S/W compiled on Jun 2 2005, 18:49:54
GSP S/W compiled on Jun 02 2005, 14:16:48
System Bootstrap Version: 6.1(5)
Hardware Version: 2.4 Model: WS-C2948 Serial #: JAB05120BDF
Mod Port Model Serial # Versions
1 0 WS-X2948 JAB05120BDF Hw : 2.4
Gsp: 6.4(17.0)
Nmp: 6.4(17)
2 50 WS-C2948G JAB05120BDF Hw : 2.4
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65536K 31670K 33866K 12288K 5414K 6874K 480K 192K 288K
7513 version:
IOS (tm) RSP Software (RSP-JO3SV-M), Version 12.2(19a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 30-Sep-03 01:46 by pwade
Image text-base: 0x60010948, data-base: 0x6197E000
ROM: System Bootstrap, Version 11.1(8)CA1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
1)
BOOTLDR: RSP Software (RSP-BOOT-M), Version 12.2(19a), RELEASE SOFTWARE (fc2)
CALLOCALLROUTER uptime is 5 weeks, 1 day, 11 hours, 54 minutes
System returned to ROM by reload at 05:30:09 UTC Sun Oct 15 2006
System image file is "slot0:rsp-jo3sv-mz.122-19a.bin"
cisco RSP4 (R5000) processor with 262144K/2072K bytes of memory.
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Bridging software.
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
Chassis Interface.
2 VIP2 R5K controllers (1 FastEthernet)(4 T1)(1 ATM).
1 FastEthernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
1 ATM network interface(s)
123K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
Slave in slot 7 is running Cisco Internetwork Operating System Software
IOS (tm) RSP Software (RSP-DW-M), Version 12.2(19a), RELEASE SOFTWARE (fc2)
Compiled Tue 30-Sep-03 01:50 by pwade
Slave: Loaded from system
Slave: cisco RSP4 (R5000) processor with 262144K bytes of memory.
tdrais
Level 7
Level 7
Unless the hardware is bad you are more that likely getting collisions.
The PA_FE_TX card will only run at 100m. I have had lots of issues with these cards when I did not hard code both ends to 100 full duplex.
Since you replaced your cable there is not a lot left.
I have 15m only.
I known this bug and always do it on interconnection cisco devices.
I founded that Catalyst have unresolved bug with keepalives from 7500 routers and it show this frames as error. But i have errors on router and i can't disable keepalives on Catalyst (Cisco bug ID CSCdr22809).
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a0080125913.shtml
